Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-04-2011, 11:56 PM
Cavalier9696's Avatar
Cavalier9696 Cavalier9696 is offline
Send a message via Yahoo to Cavalier9696
Horn and reverse lights wont work.
Need to get car inspected but my horn and reverse lights wont work. I have replaced to horn, checked the fuses and it still wont work. On the reverse lights, I have replaced to bulbs twice and checked fuses and still no luck. Crazy thing is, when I put in new bulbs they light up the first time I put it in reverse but nothing after that. There a short or a bad relay anywhere for both problems?
Thanks
1995 Eclipse RS 5psi
Garret T3/T4 Turbo, Procharger FMU, TurboXS BOV, OBX Evolution 35mm External WG, HKS Intercooler, Apexi DP, Apexi exhaust.
Old 05-05-2011, 06:59 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Horn and reverse lights wont work.
Almost sounds like there is too much power going to the bulbs and your blowing em... Checked the lines with a multimeter yet? I would pull out a reverse bulb and a brake bulb and compare the readings of both. I don't know any numbers off the top of my head for the range it should be within, but at least you can get a close comparison of the two since the brake bulbs are fine. Both should be about the same. At least it's a start to diagnosing the problem... Not sure why the horn would go out with this as well... Did you check your grounds to make sure you have a good clean connection there?
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 05-05-2011, 10:43 AM
I'll check the grounds to make sure. I'll have to find my meter but I will do that also thanks
reverse lights wont work...i need help TDWPgtp Grand Prix 11 05-16-2010 11:36 AM
Anyone Know which fuse I need to replace to get the horn and break lights to work? jjavelar Rabbit 0 07-10-2006 01:21 AM
95 wrangler Reverse lights wont work nhoroho816 Wrangler 0 02-27-2006 08:31 PM
2001 camry tail light and reverse light not work williamwu2000 Camry/Camry Hybrid/Vista 1 01-26-2006 01:50 AM
2003 Tahoe- Interior lights and reverse lights won't work jeepguy44 Tahoe 0 06-15-2005 12:46 AM
