Old 05-02-2011, 05:54 PM
khung88876's Avatar
khung88876 khung88876 is offline
Shade tree.
Send a message via Yahoo to khung88876
Arrow
Closed cuz ya'll think it's "GHETTO" haha who attacking who now huh? I never said any of ya'll stuff or posts was "GHETTO"
Old 05-02-2011, 07:24 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: Has anyone done this?
Hello!
I don't think it's a good idea, the engine should be "sealed" to provide maximum performance, if there are any vacuum leaks you'll have different problems from small leaks to lean conditions; In your case it seems like it's going to be a massive leak...
Some users install that type of filter at the PCV valve line to provide more ventilation to the engine (I don't know how it works with performance), this is not a good idea as your car will fail the emissions test and WILL contaminate more as the PCV system has been disabled.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 05-02-2011, 09:11 PM
olopezm's Avatar
Sorry for the confusion, I meant to say some users WITH OTHER CARS disable the PCV system with those filters...
Where does that line connects to other than the TB?
Oscar.
Old 05-03-2011, 06:33 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Have you monitored O2 sensor voltages and short and long term fuel trims to make sure you're not running lean? From the looks of it, you're still going to be pulling in some unmetered air as that tube and now the filter are both located downstream of the MAF sensor, correct?
-Rod
Old 05-03-2011, 03:30 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
that tube in your hand is called the pcv tube. I believe it is where the pcv system draws it's fresh air from. It is routed through the intake air tube to impart a bit of negative pressure on the intake end. IMO, replacing this tube with the filter has no effect on any performance parameters, but I think it looks ghetto, and would cause you to fail the visual part of a state inspection.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 05-04-2011, 12:25 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Good Point Rich, but when you mentioned "ghetto", you failed to mention the duct tape being used to hold the hot air intake duct into place.
Don't do it Khung.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
has anyone done this modd?? ford460bigblock Cavalier 2 07-12-2005 04:52 PM
BMW headlight conversion on a 2nd gen- has anyone done this? BlueBomber Cavalier 6 04-03-2004 05:37 PM
Has anyone done this? Hybrid_Sol '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 11 04-02-2004 09:38 PM
has anyone done this eclipse52 Car Modeling 1 06-04-2003 01:33 PM
Integra Cluster onto a civic....Has anyone done this? asnrefugee '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 17 02-09-2003 03:31 PM
