Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 05-02-2011, 05:33 PM
chads303 chads303 is offline
Air Conditioner Problems
Hello, This week my 99 Dodge Dakota's air conditioner began to act up. The air conditioner was working fine and then all of a sudden the air coming out became warm. Later when I started the vehicle the AC worked again, but only for a brief time and then the same thing happened. This time however, it started working again intermittently. I checked the Charge on the system and it was sky high. This wasn't due to an overcharge as the charge wasn't high before I started having problems. Any ideas to point me in the right direction for a fix would be greatly appreciated. Thanks in advance.
Chad
Old 05-02-2011, 06:28 PM
brcidd's Avatar
brcidd brcidd is offline
Re: Air Conditioner Problems
Next time it "gets warm" stop, open hood, is a/c clutch engaged? If not, tap on front of clutch with a blunt object (as in hammer handle) -
If clutch engages,- keep reading - then you have a compressor air gap issue (distance between clutch driver and pulley face is too great) - factory air gap spec is .020" - you can adjust the gap by removing clutch driver and removing a shim
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 05-09-2011, 05:18 PM
phipps phipps is offline
Mine was doing similar and it turned out to be the electric fan. If I was sitting still there wasn't enough air moving over the condenser and it overheated causing the AC to overpressure and shut down. Once it cooled down or if I was moving it worked fine.
HELP!!! 02 Buick Lesabre Air conditioner broken 02BuickLesabre LeSabre 6 08-17-2010 05:41 PM
Camaro A/C Problems AgKyle2010 F-Body Problem Diagnosis 4 07-20-2010 07:32 AM
Air Conditioner Compressor Cycling On and Off mafiadoller Silverado 6 06-06-2010 08:55 PM
2003 Ultra ed. - Air conditioner problem - no air gobobcats Park Avenue 4 07-24-2008 04:31 PM
Air conditioner problem in 1995 Lesabre EnderinAK LeSabre 1 06-09-2003 09:33 PM
Tags
air , conditioner
