Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 05-02-2011, 11:49 AM
010175 010175 is offline
I need the right 02 sensor help Please
I have a 1999 Suburban 1/2 ton 4X4 with a 5.7 gas engine. 247,000 miles owned from new and never been tuned up, ie no pluges, wires, ect. I am now triping a P0140 code and need to get it fixed for Californao smog. Where could I find the part number off the 02 sensor? I am going to replace the sensor and plugs and see if the code comes back. I have a cheep code checker and it say the 02 sensor is bad. Read all the posts about 02 sensor and now want to throw the part it on a guess. I want to order it off the net and dont want to get the wrong part. Thanks Dave
Old 05-02-2011, 06:04 PM
777stickman 777stickman is offline
Re: I need the right 02 sensor help Please
Go to this site and send them an e-mail with your full VIN. Ask for the part number for Bank 1 Sensor 2. This is the post cat sensor.
I can tell you that you're looking at around $100 from the dealer and $60 from the link below.
Also in the troubleshooting tree for DTC P0140, it goes all the way to step 15 before saying to replace the o2 sensor!!!
Also if you have two post cat sensors you may try swapping them from side to side and clearing the code to see if it stays with the sensor or bank 1.
Good luck.
http://www.gmpartsdirect.com/
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
The Following User Says Thank You to 777stickman For This Useful Post:
010175 (05-03-2011)
Old 05-02-2011, 06:27 PM
j cAT j cAT is offline
swap the upstream O2 sensors ..write down the O2 sensor NUMBER..see if the code changes...when removing look at the wire for damage..140 code is usually a damaged wire..could be just too old..
240,ooo mi is far too long on replacing. spark plugs must be way out of proper gap with 240,ooo on them..
replacing the both upstream sensors with the same manufacturer is best ..with this vehicle I would go to the scrap yard and get them !
you could also get the plugs there also ........
The Following User Says Thank You to j cAT For This Useful Post:
010175 (05-03-2011)
Old 06-25-2011, 05:21 PM
Found the O2 wire off due to a trans change. Plug back in and cleared code. Passed CA smog. Dave
Old 06-25-2011, 07:11 PM
thanks for that info ...good luck with the vehicles repairs
3300 v6 not firing right help please!!! hyorinmaru Grand AM 8 07-31-2009 03:02 PM
1997 Blazer starting problem, working on it right now, help please crzyakta Problem Diagnosis 2 02-26-2007 12:49 AM
Need the right amp! LeaTHER OpT. 28 Car Audio 2 11-10-2005 08:23 AM
My Lumina Starts the shut off right after!!! HELP!!! Please!!! Decebal Lumina 11 08-17-2004 06:52 AM
o2 sensor help please. 91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 1 08-03-2003 12:08 AM
