Old 05-01-2011, 08:08 AM
RobbWis RobbWis is offline
99 cavalier Drive axle question
I am changing the wheel bearing in my 1999 cavalier. The problem I am having is getting the drive axle to come out of the hub. Have tried tapping it with a punch like Haynes says, and I also tried the 2 jaw puller method they discuss. Neither worked for me. The drive axle still won't budget. Does anyone have any other suggestions?
Old 05-01-2011, 11:01 AM
mcmalloy mcmalloy is offline
Re: 99 cavalier Drive axle question
as long as you have taken the big nut off and the three bolts on the back side of the bearing it should come off
The Following User Says Thank You to mcmalloy For This Useful Post:
RobbWis (05-01-2011)
Old 05-01-2011, 11:26 AM
Done all that and the hub will still will not come off the drive axle. I can get the hub to separate from the knuckle, but that is it.
drive axle and boot question scarylarry Grand AM 2 02-12-2009 03:12 PM
89 cavalier drive axle removal jimmy1977 Cavalier 1 02-17-2005 10:44 PM
Drive axle question zippeay Engineering/ Technical 3 07-18-2003 07:34 AM
Tags
bearing , driveaxle , hub , stuck
