Old 02-12-2009, 11:47 AM
scarylarry scarylarry is offline
drive axle and boot question
i have clacking coming from my right front drive axle and i noticed the back clamp on the boot is off.could it be that its got alot of contaminates in there and needs a new boot kit and grease or do i need to replace the drive axle ?
Old 02-12-2009, 12:00 PM
doctorhrdware doctorhrdware is offline
Re: drive axle and boot question
It sounds like the CV joint is toast. I do not think that replacing the grease will help. You can try it to see if it will work but odds are you will need to replace the axle.
Old 02-12-2009, 03:12 PM
J-Ri's Avatar
J-Ri J-Ri is offline
I wouldn't waste the money on the clamp, if it's got to the point where you can hear it, the damage is done. Replace the whole shaft.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
