Go Back   Automotive Forums Car Chat > Buick > Regal
Old 04-30-2011, 08:57 PM
mn_1 mn_1 is offline
Car running warm
Drove it for the first time on the highway yesterday. When I went thru the McD's for a drink the temp gauge was about 5/8 of the way across. AF is newer and full, but you know I never did hear the fans kick on. Back on the highway it went back down again. Outside temp was about 75 or so. Thermostat was replaced a couple years ago. Shouldn't the fans be on? When I got home and shut it down, they weren't on then either.
Old 05-07-2011, 07:43 PM
Re: Car running warm
Anybody?
Old 05-07-2011, 08:10 PM
tempfixit tempfixit is offline
Originally Posted by mn_1 View Post
Anybody?
Yes the coolant fans should come on at a certain temp. You need to check the fuses, relay and check to make sure the fans do work by making sure they have curren to them. I would take a ccouple of wires and makes sure they work, then fo from there. Could also be a faulty ECT. For some reason the thread title on the list does not match question.
Old 05-07-2011, 09:34 PM
I changed it is why. Wasn't getting any replies to the window thread..............
Old 05-07-2011, 09:38 PM
Re: Drivers door window regulator
Do the fans work when you turn on the AC??
Old 05-08-2011, 12:10 AM
Will check today and report back.
Old 05-08-2011, 08:46 AM
brcidd's Avatar
brcidd brcidd is offline
Fan will work with a/c only when a/c head pressure hits 175 psi-- is your a/c up to snuff?
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 05-08-2011, 08:49 AM
bozr's Avatar
bozr bozr is offline
The fans turn on at low-speed around 223 degrees and high-speed at around 230. Parked and idling with the heater off should eventually bring the temperature up high enough to turn the low-speed fans on.
Depending on sensor/gauge accuracy it may be closer to the 3/4 mark.
To test the fans, disconnect the connector at the coolant temperature sensor located at the thermostat housing. Start the engine, after a slight delay both fans should come on at high-speed (CTS fail mode).
I love the smell of Stoichiometric in the morning.
The Following User Says Thank You to bozr For This Useful Post:
mn_1 (06-05-2011)
automatic locks and driver side window not working rmwilson Problem Diagnosis 5 06-23-2010 08:04 AM
window regulator daspyderman LS | MKZ 6 03-09-2009 03:07 PM
Window regulator troubleshoot anfrhm Sidekick 0 02-19-2009 12:40 AM
Driver door window regulator Poe Rendezvous 1 12-05-2007 07:22 AM
'94 2-door Metro driver side window regulator needed chembrad Metro 5 04-03-2005 05:12 AM
