Old 04-30-2011, 01:23 PM
George1 George1 is offline
power brake problem
It's an F-250. 1989. Just touching the brake pedal will lock the brakes up in the extreme of this problem. Other times the brakes engage and lock up and I must use a toe to pull the pedal back. Sometime I can push the pedal in and the brakes will hold, again I must use my toe. Sometimes the pedal will slowly return up. Intermittant problem, sometime they work well. I have given the pivot a shot of 40 and that seemed to help a bit. Also shot the rod where it passes through the firewall. Thought that driving a bit in reverse might help but it didn't. Also a sort of squishing sound when I pump the brakes.
Old 04-30-2011, 07:28 PM
inafogg inafogg is offline
Re: power brake problem
Originally Posted by George1 View Post
It's an F-250. Just touching the brake pedal will lock the brakes up in the extreme of this problem. Other times the brakes engage and lock up and I must use a toe to pull the pedal back. Sometime I can push the pedal in and the brakes will hold, again I must use my toe. Sometimes the pedal will slowly return up. Intermittant problem, sometime they work well. I have given the pivot a shot of 40 and that seemed to help a bit. Also shot the rod where it passes through the firewall. Thought that driving a bit in reverse might help but it didn't. Also a sort of squishing sound when I pump the brakes.
what year is the truck??
have you pulled all wheels & checked the brakes??
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
1995 Jimmy Power Brake Problems baybum Problem Diagnosis 2 04-24-2008 01:35 AM
Power brake problem nator_0007 F Series 4 11-30-2006 09:35 PM
power brake problem? rick_b_48185 Silverado 5 11-26-2004 02:02 PM
Power Brakes Problem :-/ HELP! TheNakedCowboy1 Blazer 1 02-08-2004 06:21 PM
