Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 04-29-2011, 01:27 PM
me and you me and you is offline
digital mileage & rpm reader comes on and off - any one know why??
digital mileage & rpm reader comes on and off - any one know why?? 1996 seabring conv.
Old 02-08-2012, 09:59 PM
Footer2000 Footer2000 is offline
Re: digital mileage & rpm reader comes on and off - any one know why??
go to:
http://www.automotivehelper.com/topic232004.htm
Old 02-08-2012, 10:12 PM
fuegofan
12-16-2004, 10:55 PM
I found the problem, apparently common on this model. On the circuit board behind the dash display there are three resistors soldered so close to the circuit board that they overheat it. After time, the solder joints lose their integrity. The mileage is recorded correctly elsewhere in the vehicle, but the tach and odometer display becomes intermittent.
I easily repaired the board with help from an electronics-savvy friend. I replaced all three resistors (two big 12-ohms and a smaller 13-ohm one). The autopsy showed they were not actually bad, just their connections to the board. I resoldered the replacements farther off the board to allow air to circulate better. The displays work fine now.
It's not difficult to get to the circuit board behind the dash. You have to be gentle and patient in removing the various plastic trim parts. You will need a phillips screwdriver, a proper-sized torx screwdriver and a soldering iron. Cost for 3 new but unneeded resistors from an electronics store (not Radio Shack) was $2. Good luck!
Tried the above fix by simply adding solder to the resistors (it is real obvious which ones they are especially when you see the joints) worked perfectly. Would advise using this fix instead of replacing gauge cluster because you eventually will get the same problem. Better to know how to fix it. Only costs solder.
93 Lesabre Stalling and no one knows why TheDeal526 LeSabre 10 06-01-2007 08:31 PM
does any one know why........ teemsta Grand Cherokee | Grand Cherokee SRT8 2 06-10-2005 05:21 AM
i carpet for a 1967 camaro and seat covers any one know where i can ger it from civic_racing_01 Camaro Discussions 3 01-12-2005 07:57 PM
Does any one know anything about off-roading? bluez28guy Hummer H1 4 09-17-2003 11:14 PM
does any one know if nissan will continue to make SER and SER spec v sentras in 2003 SER spec V Sentra | 200SX (USDM FWD) 10 10-07-2002 10:09 AM
