Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-28-2011, 06:12 PM
tigerstyle64 tigerstyle64 is offline
was replacing thermostat and a problem occured
I was replacing the thermostat on my 2002 dodge ram 1500 and the bottom on the the two bolts was cross threaded i am assuming by the factory because it looks to be the original thermostat but I tried to ease the bolt out of its place and it snapped off on me. Does anybody know a good solution to my problem or what I should do I was thinking of drilling out the bolt and re-tapping the hole for a new screw but I was not sure if that would mess anything up because of any kind of precision machining or something but I went to see if I could get my drill in the small gap and I can;t anyways I also didn't feel very comfortable doing it by hand and thought it should be done by a drill press but if anybody has any good solutions I am all ears thank you
Old 04-28-2011, 07:03 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: was replacing thermostat and a problem occured
Which engine?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 04-28-2011, 07:07 PM
the 4.7L V-8
Old 04-28-2011, 08:15 PM
brcidd's Avatar
brcidd brcidd is offline
Probably was not cross threaded, it was in an open threaded hole, where the end of the bolt protruded into the water jacket, and the threads became corroded- such that after you broke it loose, the bolt became tighter, and then it snapped while trying to take that corrosion through the threads in the hole. When this happens to me, I seriously think twice about changing the thermostat- and put it back.
Now you are in a pickle...only answer is to drill and tap new hole..
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 04-29-2011, 05:55 PM
AF - Advisor
Is that the one with the thermostat housing low on the passenger side of the engine?
Old 04-29-2011, 07:26 PM
FishFind FishFind is offline
One Hot Shot
You can try and drill it and use an easy out.
Old 04-29-2011, 09:21 PM
aleekat aleekat is offline
Never had any luck with easy outs. they normally break on me. Some pblaster or kroll. Left twist drill bit if you can reach it.
Old 04-30-2011, 01:36 PM
I grinded it off as best as i could went to drill it and it would not drill that easy. What I have done and it seems like it has fixed it I have let it run no leaks and it is on there as solid as I can get it... I took a all metal C clamp and i tightened it down as much as I could then tac welded the threads so that the C clamp wouldn't back off of the housing it seems to work very well and It is on there and won't even shake
Alternator stops working around 2800 rpm?? Replaced alt and still occurs! HELP! bjrjr16 S-10 1 01-13-2010 08:31 AM
please help. boyfriend replaced thermostat and now won't start nine99 Accord/TSX/Accord Hybrid 4 03-10-2006 07:11 PM
Replaced Thermostat and.......... Eddie57 Altima 9 05-03-2005 07:42 PM
