Old 04-28-2011, 08:14 AM
jaygio31 jaygio31 is offline
cv joint trouble help me
when i am turning right it seems the drivers side front wheel is kind of clunking only when turning. i checked under the car and dont see damage to the boot at all. is it still part of the cv joint? what couyld it be? can i drive the van?
Old 04-28-2011, 07:24 PM
tempfixit tempfixit is offline
Re: cv joint trouble help me
Grab the cv shaft and see if there is any movement, if movemnt more than likely knuckle on shaft is bad even tho the boot is ok. Check all of your suspension( tie rod ends, ball joints, etc.) You can drive it but could leave you stranded. Does it clunck or more like a clicking when turning.
Old 04-28-2011, 11:12 PM
well i drove it to work today only about 7 miles and it isnt making the same sound it was before. Now it seems like a creaky "woh" sound, like low power steering fluid sound only not as bad. no noise when driving straight
Old 04-29-2011, 11:27 AM
joeuser742 joeuser742 is offline
What year is the van? If it's a 99-03, then I would take it in for the front subframe recall.
Old 04-29-2011, 11:29 AM
Wait a second, that kind of sounds like a bad strut mount.
Old 04-29-2011, 04:21 PM
yeah i starting thinking something alond those lines due to the noise, is that expensive or something i can fix
Old 04-30-2011, 09:31 PM
I did mine myself when I replaced the struts. You have to take the strut off and compress the spring. I used 2 sets of spring compressors from harbor freight, just to be on the safe side. Once you take off the strut, you're also going to need an alignment. The mount usually costs around $40-$50.
If you want to avoid the wheel alignment, you could take the control arm off with the strut still bolted to it, but it is more work and a little heavier.
ball joint? tie rod? HELP! cjedstrom Cougar 2 11-26-2009 05:53 PM
U-Joint trouble mallarkeys Dakota 2 08-23-2007 06:47 PM
91 Park Avenue Ball joint trouble volkerc Park Avenue 2 08-26-2006 06:16 PM
Ball Joint Trouble oldsgal442 Cutlass Series 0 05-18-2006 06:53 PM
CV Joints? NEED HELP??? DroppedLoEclipse99 Off-Topic 7 01-16-2004 10:49 AM
