Old 04-27-2011, 11:30 AM
jack_x jack_x is offline
Question Are frequent jump starts bad for your car?
Hi all,
I have a 2002 Honda Accord that I do not drive very much.
I'm having to jump start it often, and wondering if this is bad for the car in any way? Particularly the electronics.
The reason for my concern is that my gear was stuck on park for the first time and had to use the key-in-slot method to release it. After googling a bit it seems that can be due to electronics failure.
I know the correct way is to use a car battery maintainer to trickle charge it, unfortunately I live in an apartment so I do not have access to an external power source.
Appreciate any advise regarding frequent jump starting.
Thank you.
Old 04-27-2011, 07:36 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Are frequent jump starts bad for your car?
why not disconnect the battery in between uses?
you could hook up a simple 'on' 'off' switch to cut the power from the battery.
biggest drawback with that is you would lose all saved presetsin things like your radio/ memory seats, etc.
Old 04-27-2011, 11:32 PM
Thanks for the tip. I don't know how to do that exactly I'll research it.
But does the battery use that much juice when the car is turned off? In my accord nothing stays on with the exception of the tiny digital clock, which isn't even backlit.
I was assuming the issue is that the battery doesn't get fully recharged when the car is driven. It is driven only once in a while, and when it is driven, it only goes short distances.
Old 04-29-2011, 07:48 PM
BullShifter's Avatar
There are more things than just the clock that need power. The radio presets, security system, etc. are always monitored. You can buy a quick disconnect for the battery from any parts store or just disconnect the battery(negative cable)
Please help us in jump-starting our website. autionprojapan Dealer Experiences 0 07-08-2010 03:18 AM
Is double-clutching bad for your car? Kinked210 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 19 07-26-2004 08:07 PM
is coasting in neutral bad for your car? Jotosuds '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 6 08-02-2002 07:46 PM
