Old 08-01-2002, 08:01 AM
Jotosuds Jotosuds is offline
is coasting in neutral bad for your car?
someone told me that coasting in neutral at higher speeds (80mph) is bad for your car. is coasting in neutral bad and should you downshift instead? one guy said that coasting in neutral wears out your brakes too much. what do you guys say?
har har...
Old 08-01-2002, 09:45 AM
iLLuCiv99's Avatar
iLLuCiv99 iLLuCiv99 is offline
Send a message via AIM to iLLuCiv99
well I think what he means by 'bad' is that when u put it back 'in gear' you might be putting lots of 'pressure' on the tranny at one time. but I dont see there being a problem if ur cruising...and the thing about the brakes? thats only if ur stopping right? u can down shift when ur slowing down, but that also makes the tranny work a little harder...
J+L
Old 08-01-2002, 11:08 AM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
what he said basically the RPM is dropped back to idle, but the car's clutch is not engaged so the only thing that is moving the car is it's own momentum (sp?) if you want to get back into gear, try to rev match the car.
Old 08-01-2002, 01:50 PM
ahh i c. too much pressure on the transmission. another thing. my friend said that rev-matching wears out your clutch. i thought it did the exact opposite. what gives?
thx for responses
har har...
Old 08-01-2002, 05:27 PM
PoisonFangs PoisonFangs is offline
Banned
Send a message via AIM to PoisonFangs
Where did your friend get his information? I think he needs to check it again.
Old 08-02-2002, 07:45 AM
i don't know where he got that. but i don't see how it would right?
har har...
Old 08-02-2002, 07:46 PM
Bryan8412 Bryan8412 is offline
Send a message via AIM to Bryan8412
thx for responses
you're both wrong, it saves wear on the synchros which do exactly what rev matching does, but physcially on the gears and they wear under extreme shifting conditions like what you mentioned and others. synchros are what prevent the need for double clutching like old cars did aka rev matching.
mmmmmm.... :jump:
