Go Back   Automotive Forums Car Chat > Ford > Contour
Old 04-26-2011, 01:32 PM
Oldmercsrule Oldmercsrule is offline
1995 Ford Contour 2.5 L v-6
Hi folks new to the board.
I bought a 1995 Contour fer me Lady Friend.
Checked the brakes 90%; bearings great; changed oil; 132,000 miles and VERY clean... straight and runs very good.
It would do a little black smoke when she first fired up n' run a little ragged so I changed the fuel filter n' that seemed ta cure that issue.
I gotta find someone with a scope so I can check the corndition of the spark plugs n' wires, (wires n' cap look good as does the air filter), I may jus' change 'em (platinum plugs go 60,000 I hear tell).
Here is me only issue: the check engine light cums on from time to time.... The previous owner claimes this is an "issue" with the 1995 first generation Fords.... or sooo his mechanic said... maybe... maybe not....
The codes are "DTC 111" which means nothing..... (I think anyhoo)..
press another button fer the memory and:
DTC 176 "insufficient O2 sensor" whatever that means....
press again and:
DTC 332 "insufficient EGR signal" whatever that means...
After I changed the fuel filter n' ran some Seafoam n' Chevron injector cleaner, (separate tanks of gas), she is runnin' reeeeel sweet...
What say you big guns on this site?
Thanks in advance.... fer yer help
Murky
1990 2.5 NO spark in plug #3 and #4 UseDaGreyMatter Lumina 10 11-29-2010 06:57 AM
motorcraft spark plugs for 1995 2.5 liter 6 cyl contour bodetteplant Contour 6 05-10-2007 09:24 AM
1995 ford contour 2.0 timing belt change teddie1960 Contour 4 03-04-2007 06:59 PM
95 Ford Contour, 2.5 Automatic Trouble starting in cold dc911 Contour 7 12-20-2005 08:22 PM
1995 Ford Contour 2.0 auto tranny problem....ELECTRICAL? JUNKYARD? killer_cr80r Contour 7 07-21-2004 08:12 PM
