Go Back   Automotive Forums Car Chat > Ford > Contour
Old 05-09-2004, 03:25 PM
killer_cr80r killer_cr80r is offline
1995 Ford Contour 2.0 auto tranny problem....ELECTRICAL? JUNKYARD?
I have a 1995 Ford Contour 2.0 auto and I have some serious tranny problems now......What happens is that when I am driving the tranny upshifts downshifts constantly with same throttle pressure and sometimes it acts like it goes into neutral then back into gear........This kills the S**^ out of the car goes to neutral hits rev limiter then slam back into gear. I was driving normally when this happened.......... Neone know what is wrong? It has been slipping from drive to overdrive for quite some time.............
Old 05-09-2004, 05:53 PM
zx2srdotnet's Avatar
zx2srdotnet zx2srdotnet is offline
Banned
Send a message via AIM to zx2srdotnet
Re: 1995 Ford Contour 2.0 auto tranny problem....ELECTRICAL? JUNKYARD?
ford i4 tranny's are crap, id take it to a mechanic
Old 05-17-2004, 08:06 PM
AlWicz AlWicz is offline
Send a message via AIM to AlWicz
Hey, what did you end up doing with that? If your just gonna junk it, Im looking for a 95 contour passenger side door....
Old 05-29-2004, 09:35 AM
tinamarie5761 tinamarie5761 is offline
Have you found out anything about your car?
I have the exact same problem on my 95 contour 2.0.
I am frustrated and need help.
Old 06-13-2004, 12:51 AM
TANUSHEV TANUSHEV is offline
Please check your trany fluid(Low fluid!!!!)!! Check it when the engine is running in "PARK"
Old 06-30-2004, 10:14 PM
dp62273 dp62273 is offline
Send a message via Yahoo to dp62273
first check the trans fluid.add if needed.i would take it to a shop and have the trans flushed.clean the mass air flow sensor.
Old 07-08-2004, 12:44 AM
ggarzaap2003 ggarzaap2003 is offline
tranny prob
We replaced the Manual Lever Position Sensor and it ran fine for a while, but within 2 months we had to get a new transmission! Ours was doing exactly what you described.
Old 07-21-2004, 08:12 PM
Car Pal Car Pal is offline
sounds like the speed sensor giving bad signals.
