Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 04-25-2011, 08:37 PM
mdlopez mdlopez is offline
Red face 93 Lincoln Putting
My car is putting when I step on the pedal from a dead stop. If I warm ot up for 15 min or so it doesnt putt as much but still does. We put it on the machine and the code came back with the secondary circuit for the fuel pump can anyone help.
Old 04-25-2011, 10:16 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: 93 Lincoln Putting
Hi and welcome to the forum!
What was the exact code you pulled from the PCM?
You might have a problem with clogged EGR channels. if you step too much on it will it backfire or act like it's running on fumes?
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 04-26-2011, 06:58 PM
the code was like 542 and when you step on the pedal hard it backfires under the hood not the tail pipe.
Old 04-27-2011, 09:49 PM
olopezm's Avatar
The backfire under the hood might be an indicator of clogged EGR channels, you might want to take a look at them using this tech tip:
Click here
542 DTC: Fuel pump circuit open: PCM to motor.
Maybe the wiring is corroded between the fuel pump and the PCM causing an erratic operation which at the same time is responsible for the lack of power.
AFAIK the most common place for corrosion is right at the fuel pump, you'll have to lower the fuel tank to inspect the connections at the pump.
Oscar.
94 Lincoln Continental: Lights won't turn off TheWampusCat Continental 8 01-12-2014 10:56 AM
Lost Hubcap Wrench for 1985 Lincoln T.C. James616 Town Car 2 06-21-2009 12:45 PM
Lincoln C concept (2009) bigligne General Discussion 0 05-12-2009 06:33 AM
91 Lincoln TownCar Signature Series - No power 91lincoln Town Car 7 04-22-2009 11:46 AM
2002 Lincoln Continental oddendz Continental 1 03-01-2009 09:50 PM
