Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 04-25-2011, 08:51 AM
thecrow1986 thecrow1986 is offline
2001 chevy impala headlight problem
when we first start the car the headlights flicker for a couple of seconds then stop. the daytime lights work fine. when u shut the car off sometimes the lights flicker on and off for a while. after a while it will stop. while its flickering if u pull the headlight switch to on it will stop. but after u turn back off it starts again not sure whats causing this to happen. the headlight relay does make a lot of clicking noises while this happens
Old 04-28-2011, 09:13 PM
2001 chevy impala 3.4 elecrical issues?
my uncle has a 2001 chevy impala 3.4 and the problem is that when the car is off or while its on the headlights flicker and so does the instrument panel. its like the headlights are being turned on and off. and while this is happening if u pull the headlight switch on the problem stops but once u turn the switch off it starts again. could there be something worn out in the switch?
Old 05-25-2011, 09:56 AM
SierraK1500's Avatar
SierraK1500 SierraK1500 is offline
Exclamation Re: 2001 chevy impala headlight problem
Replace the switch. Also grab an electrical diagram and have the automatic light sensor checked and the circuit also. I also had this problem and replaced the switch. Works well.
Old 06-01-2011, 08:51 AM
changed the switch and it still is the same. if i pull the fuse for the bcm/cluster the problem stops
Old 06-02-2011, 09:15 PM
HeMi101's Avatar
HeMi101 HeMi101 is offline
Send a message via AIM to HeMi101 Send a message via MSN to HeMi101 Send a message via Yahoo to HeMi101 Send a message via Skype™ to HeMi101
Sounds like your BCM may be fried. Another common POS part in these cars.
2000 Chevy Impala Headlights Don't Work LadyQueen61 Impala | Impala SS 34 01-14-2017 10:55 AM
2001 Chevy Cavalier Coolant System Problem getwilde Cavalier Problem Diagnosis 0 09-18-2009 06:43 PM
2000 Chevy Impala headlight aiming? Spiritwolf Impala | Impala SS 8 02-26-2009 09:22 PM
Location Of Fuel Sender Unit - 2001 Chevy Impala Base Model aswad Impala | Impala SS 3 07-09-2005 11:23 PM
2001 Chevy Impala Problems Mcknwbrdg Impala | Impala SS 4 06-24-2004 06:45 PM
