Old 04-24-2011, 10:59 PM
Ktribb Ktribb is offline
bought a 91 civic base hatch 1.5 4-speed, in need of help on ignition troubles
So I've posted this on honda-tech forums and nobody wanted to help, as is usually my case whenever I post anything on a forum.
Have replaced an ignition switch twice and problem still exists, car starts with key, or screwdriver into the ignition harness, before i plugged it back into the end of the key switch... but it won't shut off with the key, I need to put it in gear and slowly off the clutch, was wondering where I should start lookin for electrical problems, I have also noticed that the 12v power is shorted, as it shut my phone off as soon as I plugged it into the charger. Anywhere to start would be greatly appreciated! I currently have a HIDs on the car, and that's pretty much it.
Old 04-25-2011, 10:12 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: bought a 91 civic base hatch 1.5 4-speed, in need of help on ignition troubles
are you sure you used the correct ignition switch? A few plug in the same but the wires are different. Do you have your old one to compare. Have you checked your fuse block?
Old 04-25-2011, 10:38 PM
Checked the switch and it is the correct one, however I did not replace the key switch in the column as I tried it with the switch not hooked up to the key switch and had the same effect. I also looked online at diagrams of the different ignition switches and compared mine to what I should have, and it matches right up to what it should be.
Old 04-26-2011, 09:57 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Its not in the tumbler part of the switch, something isn't killing power to the main relay and ECU like its suppose to. I'm not currently in the state of mind to think of a good answer though.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 04-26-2011, 10:29 PM
Lol thanks Tony, next step was tumbler lol
Old 04-27-2011, 05:42 PM
Tony's Avatar
TLD Member #1
If it acts the same if you bypass the switch with a screwdriver, I know which piece your doing this on, tumbler is out of the question because you just eliminated it.
I'm not sure without looking at the wiring diagram on what could cause this, just going off the top of my head, possible main relay.
Tony
Old 07-29-2011, 01:49 AM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
My car did a lot of unexplainable things when the main relay was on the fritz. It's fairly cheap if you can replace it yourself.
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 07-29-2011, 01:51 AM
You don't have a remote starter wired into the harness anywhere do you? Just a thought?
||JEFF| |
MD - 1974 Camaro Z28 4-speed - 9k obo Cyrix_2k Cars/Parts for Sale/Exchange 1 04-17-2011 08:49 PM
Barn Found 69 Imapala SS 427 4-Speed.....need to sell BarnFindSS427 Impala | Impala SS 1 02-27-2006 02:58 PM
'93 Grand Am 3.3l; Need help accessing trouble codes tdinning Grand AM 2 08-11-2005 05:04 PM
Need help with Trouble codes 89ZCCivic '96-'00 Civic 8 05-22-2005 05:25 AM
need help reading trouble codes 92firebirdman Camaro Discussions 2 03-26-2005 03:33 AM
