Control switch
Today is the first day the temperature reached over 60 degrees and I opened the driver's side window on my '98 GP (4 door). I parked, closed the window and did some shopping. On the trip home, the driver's side window did not work. The other three switches work. Can this be a problem with the switch or the motor for the window?
Re: Control switch
You'll have to take it apart and see. Try the easiest first, take the switch off the door and check for continuity with a digital multi meter. You should get none when the switch isn't activated and the dmm should beep when activated. If the switch is OK then you'll have to take the panel off to mesaure voltage accross the window motor terminals.
Oscar.
1995 Lincoln Town Car 4.6 Signature 1997 Pontiac Grand Prix GT 3.8 2000 Ford Windstar SE 3.8 |
Re: Control switch
It looks as if the switch is bad. I have to make a choice - $242.00 plus tax for a dealer supplied one or $100.00 from the wrecker. Should I take the chance with the used one or spring for the new one. I will be keeping the car for awhile since it only has 57,000 miles on the clock and is 12 years old?
Re: Control switch
They're $40 on Ebay- brand new.
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
Re: Control switch
I have a Dorman branded one in my 99 GT 4dr and it's working perfectly, cost about $50.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
Re: Control switch
It was the switch after all. Went to the wrecker on a "all you can carry" day for $49.95 and got the switch, 2 headlamps, 2 tail lamps, a coolant overflow (for 99 models and later) and a few other bits and pieces. Not a bad day for $49.95.
Re: Control switch
Oops, I forgot.......Thanks again for the help.
