Old 04-23-2011, 12:23 PM
tempfixit tempfixit is offline
Serpentine belt ?
98 3.0L engine 208k
I had a jerping noise on my serpentine belt area so I installed a new oreilys belt (cheaper brand ) was fine for a whiole then started again.
To date I have replaced the water pump, idler pulley. Then replaced serpentine belt with a carquest belt (cheaper gates) drove for a couple weeks, no noise then it started again. Replaced serpentine belt tensioner pulley no change. Today I did the old trick of applying bar soap to the belt
with the aid a channelock plier. The noise has stopped.
Wondering if anyone else has had this problem and finally found a belt that doesn't make a embarassing noise while driving down the street?
thanks
Old 04-23-2011, 02:00 PM
jayjp200 jayjp200 is offline
Re: Serpentine belt ?
Hello,
I had a similar problem few years back and I kept changing the belt, tensioner and idler pulley bearings.
It turned out tobe the cam shaft position synchronizer. It is right behind the water pump under the sensor.
You will need a special tool to allign it (Tool is a must) - if you decide to replace it. Rock auto has a good price on the assembly.
Last edited by jayjp200; 04-23-2011 at 05:29 PM. Reason: Name corrected for a sensor
Old 04-23-2011, 02:06 PM
12Ounce 12Ounce is offline
ditto.
Do a seach on "cam position synchronizer".
Old 04-23-2011, 03:36 PM
Originally Posted by 12Ounce View Post
ditto.
I thought of that also but the camshaft sensor and synchronizer are on the rear of the engine on a 3.0L engine, unless the sound travels from the back of the engine to the front via camshaft. I also have listened with a stethocscope and it was not noisey. I will check it again.
thanks
Old 04-23-2011, 07:17 PM
Sorry ... didn't notice the 3.0!
Old 04-24-2011, 07:41 AM
wiswind wiswind is offline
The 3.0L is a VERY popular motor, just not in the windstar....maybe 6% have it.
I do not know how active the Tarus room is, but there might be information in there as it is a popular motor in that vehicle.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 04-24-2011, 06:55 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
I've used goodyear's available at autozone with good results for my pontiac and the windstar. I used gates for the lincoln and so far so good. I recommend both brands.
PS. I remember seing some serpentine belt 'grease' at autozone some time ago. Not pretty sure what it is for... You might want to take a look at it.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 04-24-2011, 07:37 PM
Oscar.
Thanks Oscar, I will check out the grease. Did you use the cheaper belt or the higher priced one??
Old 05-03-2011, 09:20 AM
Windstartled Windstartled is offline
Interesting stat, I had always wondered about this since I have yet to see a Windstar with the the 3.0 engine, and I have seen at least 100 Winnie engines counting my frequent boneyard forays.
Old 05-03-2011, 11:21 AM
olopezm's Avatar
Sorry that I didn't reply to your last post, I didn't see it :s
I used the cheaper one (goodyear) on the windstar; it was about a year ago when I replaced it and haven't had any problems so far.
Oscar.
Old 05-03-2011, 11:24 AM
I believe '99, perhaps '00, was the last year for the 3.0 in the Winny.
serpentine belt help...please suzuki19 Cavalier Problem Diagnosis 2 07-10-2011 06:15 PM
replacing a serpentine belt schri00 Diamante 2 07-12-2010 08:00 PM
Serpentine Belts & Tranny Fluid Don't Mix!- HELP! Alphabravo Caravan | Voyager 9 10-18-2009 03:47 PM
How to Tighten Tensioner on Serpentine Belt - 05 G6 donnap1957 G6 0 02-26-2009 09:01 PM
Serpentine Belt - Belt Tensioner - Idler Pulley fdunford Windstar 1 02-03-2006 05:11 PM
