Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 04-23-2011, 10:35 AM
ClearHooter ClearHooter is offline
Black Fuel Smoke Backfire Busted New Muffler
I went through 30 pages and didn't see anything related to this question. If it's been answered prior it's time to readdress the question.
'87, carbed, 2WD, 5spd, truck.
When cranked from cold much black fuel smoke is present. Pulled the air cleaner top and primary choke plate is open. Secondary isn't. When secondary is opened smoke stops and idle smooths out when plugs clear.
If I recall (it's been many, many years) the heat mass on the primary is operated by electric current. What operates the secondary? It IS supposed to be open when warmed up....Right?
A new exhaust was installed W/O cat.con. Unburned exhaust was so bad it must have ignited and blew the muffler seam out.
Any help would be appreciated.
Old 04-23-2011, 01:09 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Black Fuel Smoke Backfire Busted New Muffler
Is it possible your carb is leaking gas out of the bowl and dumping it into the intake when it is sitting? I don't think the secondarys open unless the throttle is significantly opened. I don't know if the secondarys are vacuum or mechanical.
The float level may be too high also.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 04-23-2011, 09:45 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
The choke is electric, everything else is mechanical.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
2.4 blowing black smoke cr_rider Mighty Max 5 12-31-2010 02:56 PM
96 GMC Jimmy black smoke, backfires, Timing? corhey88 Jimmy 38 01-31-2010 03:29 PM
Lots of smoke out of the muffler AcesHigh Prelude 13 12-15-2004 05:06 PM
Talon Smoking/Backfire Sputnic90TSi Off-Topic 2 06-04-2004 11:30 PM
Low fuel milage and black exhaust smoke SESH1 Corsica 2 10-27-2003 01:48 PM
