Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 04-22-2011, 12:12 PM
Pierutrus Pierutrus is offline
Starting issue after gas fill up
05 Sonata with a 6 cyl.
A couple of months ago the car would die at red lights but would start right back up and you were on your way.
Now for the last 4 or 5 times I've filled the gas tank, the car will not start directly there after to leave the gas station. It takes 3 or 4 times of trying to start before it starts running and I can leave. Then the car runs fine until the next fill up.
Is this a gas cap issue?
Thanks in advance for any replies!
Old 04-27-2011, 12:20 PM
Re: Starting issue after gas fill up
Anybody?
Old 05-07-2011, 09:30 PM
Well I can tell this place SUCKS.
Old 06-08-2011, 08:45 PM
semisendiz semisendiz is offline
I thought I might find an answer to the same exact problem I have with my '05 Sonata 2.7L V6.
Apparently I was wrong.
I'll keep looking and see if I can find some answers.
Good luck.
Old 07-28-2011, 03:56 PM
Found out it was the PURGE CONTROL VALVE located in the engine compartment right behind the intake manifold. Just look right behind the center of the engine and the firewall it is right there, tucked right behind the intake!
SOLVED the problem.......
Found the part at WWW.ROCKAUTO.COM for $22 delivered to my door.
Old 12-28-2011, 08:22 PM
sirloy sirloy is offline
Good luck.
The dealer should have a service bulletin on the problem and it may as simple as resetting of the computer.
Old 01-04-2012, 07:57 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Thanks for posting back with your solution, that's good to know.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 04-23-2012, 12:59 PM
jshzlm jshzlm is offline
check for a plugged evap filter. this filter is usually located on the gas filler pipe, bolted to the side of pipe not in it. it's suppose to be serviced every 30k if in dusty conditions.
Service Engine Soon light after gas fill up Kettledrum Intrigue 10 10-03-2006 12:49 PM
Problems after gas fill-up! jessdela Optima | Magentis | Lotze 4 09-28-2005 06:40 PM
S-10 Blazer lost power after gas fill-up. BlazerBurnt Blazer 3 08-22-2004 12:35 AM
S-10 Blazer lost power after gas fill-up. BlazerBurnt S-10 4 07-16-2004 07:27 PM
99 4.8 Backfiring after gas fill-up Bill-SILV C/K 5 06-16-2004 07:26 PM
