Old 04-22-2011, 10:37 AM
13 shorty 13 shorty is offline
Exclamation 1999 Grand Prix differential EXPLODED
so i was driving the other day and when i went to accelerate rather quickly, the differential exploded out the bottom. i have no clue what im doing but im going to attempt to pull it out and replace it. I have done engine work and am very familiar with my car but never touched the tranny and i can not afford to take it in. if anyone has advice or know how on how to do this, i would greatly appreciate it.
Old 04-22-2011, 07:27 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: 1999 Grand Prix differential EXPLODED
No point in lying to us about it. Just say it. You went to launch it.
I have never pulled a trans in a GP but from what I hear its not easy. You have to remove the engine cradle to do so. Unless you have the proper tools and equipment you are going to have a difficult time doing it on your own.
Old 04-22-2011, 07:40 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Welcome to the forum shorty!
Stealthee is right, you need to either remove the cradle and remove the transmission from under the car or remove the engine with the transmission still attached to it (that's the way I did it when mine exploded too!). There are two differentials available and are the same size, the only difference is the number of teeth, AFAIK one provides more acceleration and the other more speed (someone correct me if I'm wrong), each corresponds to the transmission on the GT and the GTP (4T65E and 4T65E HD respectively). Both differentials are interchangeable, when I did mine I couldn't find the exact replacement and only found the one with more teeth (the transmission on mine is 4T60) I decided to go with it and after 6 years it's working great!.
If you have worked with transmission you should have no problems at all, if you haven't just work on a clean area and make sure you note the position of the internal components once you take it out, failure to do so will result in malfunction. When you remove the valve body make sure you don't loose the small steel balls in it. Since you are removing it, it would be a good idea to make a rebuild...
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 01-10-2013, 03:36 AM
helicopter23 helicopter23 is offline
Same thing happened to me I think... How much would this repair cost ???
Old 01-10-2013, 10:35 AM
Tech II Tech II is offline
You don't say what year......
A new rebuilt, $2K dollars, then labor to install....
Junkyard, maybe 400-500......but new seals and complete valve body should be installed prior to installation......
Old 01-10-2013, 11:45 AM
97 grand prix gt 145k. Guy that works on my car said for a used trannsmissions for parts and labor $900 total ?? Transmission comes with either 30 day or 90 day warrantly... debating if I should get job done.
99 Grand Prix acceleration problems MConder Grand Prix 7 12-11-2010 10:08 PM
1990 Grand prix le problem Erik23512 Grand Prix 1 11-05-2010 12:14 PM
1997 grand prix anti-theft system components Konstantin Grand Prix 8 10-13-2010 10:20 AM
98 Grand Prix Wont Start, need help ASAP! atdudonis Grand Prix 3 06-17-2010 08:57 AM
1999 Grand Am nanatraci Car Audio 5 06-19-2009 07:00 PM
Tags
differential , explode , transmission
