Old 04-20-2011, 08:23 PM
orkel orkel is offline
Intermitant wiper problems
Hey all
Here is one for the fantastic experts on this forum
I just bought a 2002 Z24, but also just found a confusing problem
The wipers would be working fine, on intermitant, but after a while, it would crawl half way up the screen and stop. If I turn he wiper off for a short time (about 2-3 minutes) all would be well again for a while, than problem repeats itself.
This problem also happens if on continous wipe, low. (Haven't tried it on high yet).
If I use single wipe, all is fine.
The mechanic at the shop told me he had already changed the switch.
It seems as if motor or relay gets hot and stops system, but is relay involved if on continous wipe? There are no unusual sounds when wiper is working.
Has anyone come across this problem?
Thanks in advance
Old 04-22-2011, 09:15 AM
Re: Intermitant wiper problems
Hi All
Just an update in case anyone else has this weird problem happen to them.
I checked with the dealership here, and one of the mechanics suggested that since the car has been sitting for a while, the lubrication in the linkages might have dried up, He suggested to spray some lube on the pivot points while system is running so hopefully some would penetrate.
I'll give it a try
Intermitent starting problems Driver2001 Grand Marquis 3 10-25-2010 05:56 PM
intermitant wipers airstream71 Suburban 8 10-24-2007 12:52 AM
1999 250 intermitent wipers not work write off Ram Pickup | Ram SRT10 3 03-19-2007 03:24 PM
intermitent wiper relay, 91 Tracker iamatracker Tracker 3 03-06-2007 05:49 PM
Intermitting wiper speed Grassburr Caravan | Voyager 3 01-29-2006 01:30 AM
