Old 04-17-2011, 10:42 PM
302Z28 302Z28 is offline
Valve adjustment
I decided to replace the head gasket on my '97 2.2 Cav. As part of the process, I had the head re-surfaced. Prior to removal of the head, I ran a compression test. The readings were: 175, 170, 168, 170. After re-installing the head, the rocker arm nuts cannot be torqued as outlined in the Chiltons manual. Torquing results in the valves being held open and zero compression. Adjusting the valves to zero lash, plus 1/4 turn results in compression readings of 210, 180, 180, 220. The valves are very sensitive to any adjustment. It seems as there is a very fine line between zero lash, the compression readings above and zero compression. I'm stumped.
Any ideas?
Old 04-21-2011, 05:50 PM
Schaff68 Schaff68 is offline
Re: Valve adjustment
might sound odd, but some car companies want you to replace the head bolts or studs after changing a head gasket or head, and some rocker arm adjusting nuts are a one time onley use, meaning you have to buy new self locking nuts each time you work on the head. some companies require that you buy .010 or .020 shorter pushrods or followers after you have a head resurfaced and some of the nuts or studs are meant to be at the very end of their adjustment once they are torqued down, so if you have installed a none GM 2.2 specific head gasket, GM should list the thickness once compressed, and had your head resurfaced, you may need to buy the proper lenght valve train components so everything adjust right. i know its a pain, but when your dealing with valve train parts, some cars dont leave you much adjustment. thats why performance engines require certain ratio rockers, custom lenght pushrods and a fully adjustable valve train. and yes i know its just a common 2.2 but if things are out by enough thousands, you may need to buy other followers or ect. as in .010 or .020 shorter so things line back up properly
Old 04-21-2011, 07:23 PM
FishFind FishFind is offline
One Hot Shot
what about the springs on the rocker arm? are they still good? You are supposed to use a mic and make sure they are in a specific range.
Need help with 327 valve adjustment gr8hse67 Chevrolet Classics 6 04-04-2010 03:28 PM
How to adjust valves? lazerphreak Engineering/ Technical 1 05-08-2009 07:22 PM
valve adjusting??? 95vteclude Engineering/ Technical 14 09-19-2004 01:39 AM
valve adjustment? rossman Maintenance 4 11-27-2001 11:47 PM
What Is Valve Adjustment For? DOHCGSR Integra 7 09-12-2001 02:11 AM
