Old 04-17-2011, 04:27 AM
wolvyreen's Avatar
wolvyreen wolvyreen is offline
Wip - bmw z3
Hello,
ok, while I'm waiting for the new kit to arrive for my Honda S2000, I have moved on to the BMW Z3.
The body has been sanded and together with the underside washed in some All purpose Gel Cleaner
Noob Question Alert: Should I be attaching the Mirrors and Side Vents on to the body before I primer and spray? I thought that I need to do that because the parts will fuse better with the plastic rather than put them on later over the paint.
Old 04-17-2011, 05:25 AM
jano11 jano11 is offline
Re: Wip - bmw z3
Depends if you are going to paint the same color with the body or not. If you paint them body color then yes, better attach them at the beginning and then blend them in before the first color layer hits the body.
Old 04-17-2011, 05:35 AM
wolvyreen's Avatar
Re: Wip - bmw z3
Yh Thats what I thought i have now edited the main post and posted some pics of the parts that I was talking about.
Old 04-17-2011, 06:42 AM
gpz900ra7's Avatar
gpz900ra7 gpz900ra7 is offline
Re: Wip - bmw z3
PM sent, hope it helps.
gpz900ra7.
MY 1:1 toy
Old 04-17-2011, 07:17 AM
ales's Avatar
ales ales is offline
Forza Schumacher
Re: Wip - bmw z3
I would attach the side vents before painting and the mirrors - after. It's way too easy to knock the mirrors off when sanding/polishing the paint
Old 04-17-2011, 07:18 AM
wolvyreen's Avatar
Re: Wip - bmw z3
Ok, quick update. I have attached the vents and the mirrors and leaving it to dry for an hour before it goes for a quick rinse and prime.
Old 04-17-2011, 08:46 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Wip - bmw z3
Cool, this is a great little kit, you should have fun with it. I did one years ago and really enjoyed it.
I'm with Ales, I would have attached the mirrors afterwards. Reason being is that they will be very fragile while you are painting the body- so be careful with them! There isn't really a right or wrong answer for when to attach them- just that each offers its own advantage/disadvantage.
How are you planning to paint it? If you have any questions, feel free to ask!
PHOTOBUCKET SUCKS
Old 04-17-2011, 09:46 AM
wolvyreen's Avatar
Re: Wip - bmw z3
Well, I'm thinking of a metallic red or black with black interior on both. I haven't decided on the body color yet.
But I do have a question about primer. I have used the search feature but nothing specific to my question.
I have red conflicting statements about sanding primer. I thought that primer is intended to show up imperfections for you to be able to correct it. So if I am not supposed to sand in between priming layers, how am I supposed to correct the imperfections?
Sorry if it is a stupid question but noobs tend to ask them :P
Old 04-17-2011, 10:45 AM
Re: Wip - bmw z3
You should always sand the primer layers until they are very smooth, otherwise the texture of the primer will show through your paint layers.
Check these:
http://www.italianhorses.net/Tutoria...mer/primer.htm
http://www.italianhorses.net/Tutoria...aint/paint.htm
http://www.automotiveforums.com/vbul....php?t=1063216
Old 04-17-2011, 11:57 AM
wolvyreen's Avatar
Re: Wip - bmw z3
Thanks for the links This helps me a lot!
Old 04-18-2011, 03:00 PM
endac's Avatar
endac endac is offline
Re: Wip - bmw z3
Good to see some BMWs on here, hope it goes well for you
Old 04-22-2011, 07:47 AM
wolvyreen's Avatar
Re: Wip - bmw z3
Ok, So Im in the process of priming and was wondering whether someone could give me guidance on how to get this piece of hair out of the body before I lay down some paint on it. I really hate the idea of having to sand it out but if that what needs to be done, then I will. If so, will I need to wash again before I lay down paint??
Old 04-22-2011, 08:26 AM
ales's Avatar
Forza Schumacher
Re: Wip - bmw z3
Just sand it out with, for example, 1500 grit sandpaper. And yes, afterwards you probably should wash the body.
Old 04-22-2011, 08:27 AM
drunken monkey's Avatar
Razor Sharp Twit
Re: Wip - bmw z3
how about I ask a question for you to answer instead of just telling you what to do?
if you don't sand it, what would you do?
AF's Guidelines
Read them.
Old 04-22-2011, 10:04 AM
wolvyreen's Avatar
Re: Wip - bmw z3
Thanks Ales, I will do so then..
[WIP] BMW M3 version 2 :) Bloody Diecast Car Modeling 39 12-28-2005 03:17 PM
WIP BMW Williams FW24 Whilhelm WIP - Motorsports 7 11-08-2005 09:07 PM
WIP - BMW 318i JTCC - AutoTech rickymodel WIP - Motorsports 12 10-22-2005 03:31 PM
WIP BMW 320i artcar - Roy Lichtenstein campenr.1 WIP - Motorsports 6 05-04-2005 11:13 AM
WIP BMW 5-series contest entry (Need opinions QUICK!!) KustmAce Graphic Manipulation 6 04-27-2005 12:10 PM
