Go Back   Automotive Forums Car Chat > Chevrolet > Tracker
Old 04-16-2011, 08:19 PM
CENA CENA is offline
2000 tracker oil problem. Where is it going? What can i do?
Hello, I have 2000 Chevy Tracker 2.0, manual trans. It does not leak or burn oil, but my oil level will go down after about 1200 miles after an oil change. About close to a quart. Where is it going? Should I change oil viscosity? I run Mobil 1 5000. 5w-30. I don't want to change to synthetic because I don't want any oil leaks to occur. Any info would be appreciated! Thanks!
Old 05-09-2011, 10:15 PM
Re: 2000 tracker oil problem. Where is it going? What can i do?
Ok, I have an update. I have noticed that my valve cover gasket looks to be leaking. Still no drips on the ground. Is it possible it burns up before dripping off the engine? 965 miles after an oil change and I am down about 1/4 on the dipstick. I revved it up and had someone look to see if it smokes. Nothing! Is the valve cover gasket easy to replace? Any suggestions please.
Old 06-08-2011, 03:39 PM
nodrogrebreg nodrogrebreg is offline
My 2000 Tracker had a similar issue. I simply tightened up the valve cover bolts (they were not very tight to start wtih) and no more leak. Otherwise, changing the gasket is probably not to difficult.
98 tracker oil problem thatguy101 Tracker 1 11-25-2008 09:38 PM
98 tracker oil problem thatguy101 Tracker 0 11-17-2008 04:45 PM
2000 Exporer oil problems soccerella Explorer | Explorer Sport Trac 3 10-21-2007 09:53 PM
friend has a big problem.....dont know what to do tacoma man. Stress Release 93 06-18-2004 05:00 PM
REALLY big problem w/ Accord, what to do? dougthegreat Accord/TSX/Accord Hybrid 2 03-20-2004 09:51 PM
