Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 04-15-2011, 08:09 PM
Allegretto's Avatar
Allegretto Allegretto is offline
Send a message via Yahoo to Allegretto
where is the pump?
i know this is a moronic question, but im going to ask anyway...is the fuel pump on a 2001 old bravada inside the tank or somewhere else? because mine just went out on me today. the car shook violently when i tried to start it, and when it did start, i couldnt hear the fuel pumps signature whine as i was driving, then it cut off. after a few tries it started and i made it home. any info is helpful
Old 04-15-2011, 10:36 PM
TRTichenor TRTichenor is offline
Re: where is the pump?
Yep, it's inside the tank. Tank has to be dropped to replace the pump.
The Following User Says Thank You to TRTichenor For This Useful Post:
Allegretto (04-16-2011)
Old 04-16-2011, 06:07 PM
Allegretto's Avatar
ok i should have known thanks...another question...is it at the top or bottom of the tank?
Old 04-16-2011, 07:17 PM
Leeann94astro's Avatar
Leeann94astro Leeann94astro is offline
When you drop the tank, you'll see the top of the pump hanger assembly.
1993 Olds Bravada 4.3L CPI
1999 GMC Safari SLE AWD
2002 Chevy Astro LT AWD
The Following User Says Thank You to Leeann94astro For This Useful Post:
Old 04-16-2011, 07:20 PM
Allegretto's Avatar
ok thanks again guys
Old 04-17-2011, 06:59 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Here's a good thread with lots of info,
http://www.automotiveforums.com/vbul...d.php?t=633098
p1495 evap code,where is the pump? fandmout Eclipse Problem Diagnosis 3 12-01-2007 08:13 AM
Where the heck is the heater inlet hose for the 2003 LS? Need to flush coolant! LordJezo Impala | Impala SS 0 04-26-2005 05:23 PM
wheres the fuel pump module RyanJ Escort 2 10-31-2004 09:58 PM
Where the *$&^ is the relay for the A/C compressor clutch? djb Integra 0 07-20-2004 09:33 PM
wheres the fuel pump on a CRX? crx hf '88 - '91 Civic | CRX | Wagon | Shuttlee 8 05-19-2003 12:54 AM
