Go Back   Automotive Forums .com Car Chat > Lincoln > Town Car
Old 04-15-2011, 06:21 PM   #1
tfgoodwin
2000 towncar stuck blowing air out of dash.
The town car will not switch its blower positon from dash down to the vents or the floor. AC/Heat both work and the speed is still adjustable. Any help is appreciated.
tfgoodwin is offline   Reply With Quote
Old 04-17-2011, 06:14 PM   #2
olopezm
olopezm's Avatar
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: 2000 towncar stuck blowing air out of dash.
Hello and welcome to the forum!
If the air keeps coming out from defrost openings then you have a vacuum leak as the flaps are controlled with it.
Check all the vacuum hoses running form the air intake in the engine to the back of the engine compartment on the firewall, there should be a vacuum distribution tree just follow the vacuum line form the brake booster and you'll see it.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
olopezm is offline   Reply With Quote
Old 09-04-2011, 11:18 PM   #3
[email protected]
pmpmrs@amigo.net's Avatar
Go to harbor frt an get a vacuum tester. Pull the control from the dash (4 bolts). Chect the vacuum @ the center hole under the "gummy bear" vacuum connector (where the black tube connects). If you cannot hold vacuum @ this connection, you'll need to replace the unit @ $189.00 exchange from Module Repair Pro Inc. in Calif. PH 818-429-7646.
He's also on e-bay.
Hi Oscar, mine works great !!!!!
Mike in Colorado
pmpmrs@amigo.net is offline   Reply With Quote
99 silverado HVAC WONT BLOW AIR THROUGH DASH VENTS WHEN PUTTING KNOB IN THAT POSITION borninabarn Silverado 8 06-30-2012 03:08 PM
S-10 just blow air out of dash vents gravyd S-10 11 08-17-2011 01:35 PM
98 blazer w/auto air delivers air out dash vents only spanky1965 Problem Diagnosis 1 12-01-2008 05:37 PM
air conditioner doesn't blow air out jes1srgt Impala | Impala SS 1 07-01-2008 08:15 PM
95 blazer only blows air out of defroster vent and under dash vents maddmike13 Blazer 2 07-17-2003 09:12 PM
