Old 04-09-2008, 04:44 PM
gravyd gravyd is offline
Unhappy S-10 just blow air out of dash vents
My 2001 4x4 S-10 just blows air out of the dashboard vents no matter where the switch is. No defroster air or air going to the floor. The heater blows hot air and the AC blows cold air but it will only come out of the dash, no other place. Could the dash control switch be bad or should I look someplace else before tearing thihgs apart?
Old 04-10-2008, 06:58 PM
dragon_kin01 dragon_kin01 is offline
Send a message via Yahoo to dragon_kin01
Re: S-10 just blow air out of dash vents
sounds like u are goin to have to rip apart ur duct work and see if ur blend door its broken. if u arent gettin air anywhere but the dash the air isnt bein rediredted. idk exactly where the blend door is but its in the duct work
FORD - Found On Road Dead, ****ed Over Rebuilt Dodge, Flip Over to Read Directions, Fix Or Repair Daily,(backwards) Driver Returns On Foot (it shows I hate ford)
Old 04-13-2008, 10:48 AM
It started working again on it's own, possible vac. problem?
Old 04-14-2008, 03:29 AM
16th hippy 16th hippy is offline
should be a palstic bulb on the hood, or in engine bay, is a vacuum canister, do think it supplies vacuum to system for mode/blend operation. would be good place to start.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
Old 04-20-2008, 05:52 PM
Thanks, that sounds like a good place to start.
Old 04-29-2008, 12:05 PM
hangun61's Avatar
hangun61 hangun61 is offline
My 96 S10 2.2 5 speed did the same thing last winter. Under the hood, I found a vacuum hose that was rotted away. A 1/4 inch hose that runs from the vacuum module to the other side of the engine comp't. Easy fix. Double check all of the vacuum lines under the hood before ripping apart your dash.
Good luck
Old 02-27-2009, 07:20 PM
carbide00 carbide00 is offline
My 2000 s-10 will not switch air flow to the floor. I have defrost and top-vent, but not Floor. Could i have the same problem with a bad hose and are the air hoses toward the bottom of the engine compartment for the floor vents?
Old 08-16-2011, 12:18 PM
rontomed's Avatar
rontomed rontomed is offline
My 1999 S10 Blazer LT 4.3L 2WD with computerized climate control will not switch air flow to the floor. I have defrost and top-vent all of the time no matter what position the switch is in, but not to the Floor. Under the hood I have replaced 2 short 5/32" vacuum hoses that connects to a T junction (the other ends where connected by feeling, I could not see them) and 1 long 7/32" vacuum hose that runs from the same T junction to under the throttle body. They where all rotted. No change in the behavior of my air vents. I can not find a plastic vacuum ball. Is it the nipple sticking out of the finder well into the engine compartment or under the Kelsey - Hayes ABS system? How can I gain access to it? Any other possible causes?
Old 08-17-2011, 07:17 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Best to start a New thread on your problem.
Give all info.
Like auto Ac controls or manual controls.
MT
Old 08-17-2011, 08:28 AM
rontomed's Avatar
Give all info.
"...computerized climate control..." indicates that it has Auto and Manual setting capabilities.
Old 08-17-2011, 12:21 PM
MT-2500's Avatar
AF - Advisor
Hit the New Thread button and start your post.
Vent flow problems are usualy vacumn to heater controls.
First thing confirm the heater controls ar getting good full engine vacumn.
Do you have good full engine vacumn to AC/Heater control?
Check with a vacumn gage.
MT
Old 08-17-2011, 12:35 PM
rontomed's Avatar
I started a new thread at the same time I posted my last reply to this thread. I will test the VACUUM.
