Old 04-15-2011, 05:23 AM
seb001 seb001 is offline
RPM goes up every 8 sec.
I have a 2000 Jimmy with only 80000km on it.
Either in park or in drive while pressing the brake, the RPM goes up every 8 seconds for about 3 seconds and goes back down to normal. It goes up by 100-300RPM.
It does it more when the car is cold. I can't tell if it also does it while driving.
Once the truck is warm, it seems to still do it every 8 sec, but the RPM does not go up by as much.
Not sure if these are related: I need a new thermostat, the existing one failed open.
Might be an EGR problem, since the NOx test was a bit high.
Thanks for the help.
Seb
Old 04-15-2011, 06:44 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: RPM goes up every 8 sec.
Seb
What engine?
Any codes or check engine lights on or blinking driving?
For starters replace the stat with 195 stat.
Confirm a good AC delco parts tune up.
Clean TBI buttery fly and MAF sensor and checkm vacumn and PCV valve.
Make sure fuel pressure is up to par.
MT
Old 04-15-2011, 07:23 AM
The engine is a 4.3L Vortec.
There are no emission codes.
When you write: "Confirm a good AC delco parts tune up", are you talking about generic stuff like air filter, spark plug, wires.
I have code reader/scanner that can read the engine signals while it's running. Is there anything I can look for specifically?
Thanks
Old 04-15-2011, 07:58 AM
MT-2500's Avatar
AF - Advisor
Thanks
Ac delco tune starts with AC delco plugs and all other AC delco parts used in tune up.
When was you last tune up?
Are you getting any check engine lights on runnning or blinking driving?
Have you replaced the stat yet?
On the scanner check for codes past present or history?
OBD11 does not giveall good sensor data only basic reading.
Here is a good start.
Missfire data.
Fuel trim data.
Engine running temt correct.
Camshaft retard settings.
Confirm all 02 sensors are in range.
Egr reading actual and desired.
TPS sensor readings
Also fuel pressure needs checked with a fuel pressure gauge for up to specs pressure.
Cold start engine running and the rechecked on the road after 3 minutes or more driving.
60/66 lbs pressure
MT
Old 04-15-2011, 12:26 PM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
I would also recommend contacting GM of Canada for more assistance. You can contact them at 800-263-3777. The hours of operation are M-F 7:30am - 11:30pm, Sat 7:30am - 6:00 EST. I hope this helps. Thank you.
Tricia, GM Customer Service.
2000 rpm goes up and down while slowing down. hckybrownie31 Monte Carlo 3 08-29-2007 03:15 PM
1992, 3.3L, ECM goes every 15 days Jernic Caravan | Voyager 3 03-01-2006 02:15 PM
Chevy Astro Van 1995 RPM goes Very High when in shifted into drive. ElChino M Bodies 1 01-20-2004 08:41 AM
