Old 04-14-2011, 01:10 AM
profKenn profKenn is offline
ignition control switch?
have a 96 Chevy 1500 w/5.7 motor. Just today, I noticed that periodically my tachometer and speedometer won't work and trans won't shift right, and the "check gauges" will either be on or flicker. Plus, the light that shows on the transmission selector won't come on. I'm wondering if it might be the ignition control switch. Any help is appreciated. Thanks!
2003 Lincoln Towncar, 165k
2002 Honda CR-V, 185k
Old 04-14-2011, 01:22 AM
Re: ignition control switch?
I guess it's really an ignition starter switch, part number 26036311.
Old 04-15-2011, 12:32 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Right, it's just called an ignition switch. I had to order one for my '95 last week due to no power to my accessories when I turned the key on: windows, radio, a/c blower, windshield wipers, torque converter won't lock up, even ABS.
It could also be a poor ground judging from you not having more problems, but the ig switch is a possibility.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 04-15-2011, 12:48 PM
Scrapper Scrapper is offline
AF Premium User
do you have a good ground from moter to body? not the ground to battery.
Old 04-17-2011, 11:14 PM
dorfboy dorfboy is offline
Send a message via ICQ to dorfboy Send a message via Yahoo to dorfboy
I would lean towards the ignition switch. It supplies power down to your transmission and the shift solenoids. Hence part of the problem. I have not worked on a 96 in quite a while, but on the newer models they have a little box with like a turn dial in them that attaches under the lock cylinder and that is all that needs to be replaced.
A/C Control Dual Zone switch assembly Not Working bigpoppabear Intrigue 4 06-22-2010 12:28 PM
Not Starting, did ignition switch - no help Royalwapiti Intrigue 10 02-10-2010 02:37 PM
Ignition Switch mb8668 Eighty Eight 9 11-01-2009 09:41 AM
Anyone know anything about ignition switches? angel_iz378 Cobalt 3 09-08-2009 12:52 PM
2000 m/c ss ignition control module problems ABADTAZ Monte Carlo 1 05-03-2009 03:53 AM
