Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 04-12-2011, 08:29 PM
rwb22's Avatar
rwb22 rwb22 is offline
Send a message via AIM to rwb22
vacuum leak at brake?
I have a 2005 Escape and have heard on occasion a vacuum leak coming from under the dash on the drivers side. I have recently noticed that when I use the brake that it stops while I'm pressing on the brake pedal. I am assuming that somehow the leak is in the brake booster and coming through to the inside. Or could this leak be something else and just happens to stop when I press on the brake? Do I have to have the booster replace or is there a "rebuild" kit of some sort?
Also, I've been getting such a difference in mpg and wonder if I could plug the vac line to the booster and drive it to see if this is the cause of the bad mpg?
94 Jimmy SLE 4x4 4.3 L Vortec
Old 05-15-2014, 11:22 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
Re: vacuum leak at brake?
Yes, it's your booster leaking. There is no rebuild kit, it needs to be replaced. As far as plugging the vacuum line, that is dangerous because you will have no power brakes, and it is hard to say if that little bit of a vacuum leak will cause a drop in mpg.
1997 LeSabre Vacuum Leak? nkmhockey LeSabre 3 12-10-2010 04:20 AM
Brake fluid leak john3mo Lumina 3 11-16-2009 04:28 PM
Vacuum reservoir leaks on 95 park ave causes vacuum leaks aarcuda Park Avenue 0 07-18-2006 08:05 AM
High Revving /possible vacuum leaks Carb88AccordLX Accord/TSX/Accord Hybrid 0 06-19-2002 11:36 PM
