Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 04-11-2011, 07:34 PM
miamibob's Avatar
miamibob miamibob is offline
TPS or IAC?
Hi All,
Got an '87 GM that has a "slight up/down idle" when first starting. Only lasts a minute or so and then is fine. Sometimes a slight stumble from a stop. Likeliness culprit be a TPS or IAC?? Car has a little over 121K and have had it from brand new. Never remember changing the TPS but did the IAC a couple of years ago. Forgot to clean out the ports before install, though. Boy was that dumb!! Let me know your thoughts!! Thanks....MB
Old 04-12-2011, 09:17 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: TPS or IAC?
Use a multimeter to check the resistance of the TPS as you move it.
It could also be a fuel pressure problem.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 04-12-2011, 06:33 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: TPS or IAC?
There is an Intake Air Temperature sensor on the drivers side front that will cause the problem you describe.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 04-12-2011, 08:16 PM
miamibob's Avatar
Re: TPS or IAC?
Where exactly is that sensor located? Looks like it is threated into something and has an electrical connector but where is it screwed into? Thanks....MB
Old 04-13-2011, 01:10 PM
Re: TPS or IAC?
Not sure about on a 5.0L, but on my 4.6L it was located on the top half of the air filter box.
Old 04-13-2011, 05:52 PM
miamibob's Avatar
Re: TPS or IAC?
Yes, I had a '93 and also currently have a '95 and on the 4.6L, that is where it is. Didn't even know a 5.0 has one? Got to check the official manual as Rock Auto does list one for the 5.0.....MB
Old 04-13-2011, 06:08 PM
way2old's Avatar
TOKEN HILLBILLY
Re: TPS or IAC?
Look on the intake between 5 and 6 cylinders. it should be licated there if I remember correctly.
Old 04-13-2011, 06:11 PM
miamibob's Avatar
Re: TPS or IAC?
Hey Good Buddy! Is that Passenger or Driver's side?? MB
Old 04-13-2011, 07:01 PM
way2old's Avatar
TOKEN HILLBILLY
Re: TPS or IAC?
Drivers side. Those little sensors are suspect to carbon build up on them.
TPS adjustment oddity caffeineaholic Caprice 15 03-13-2011 09:41 AM
Impossible TPS problem entrepa Sidekick 0 10-25-2010 07:25 PM
Testing my TPS jmunny Durango 1 12-22-2009 10:57 PM
Where is the TPS, IAC and other sensors.... Tedster General Discussion 1 07-13-2008 02:47 PM
Questions about TPS and IAC Dober89 Camaro Discussions 14 07-17-2004 07:31 PM
