A/C problem
On my 03 trailblazer the a/c has been working fine until today. I started the vehicle here at home and drove to the store about 10 minutes away. The air blew cold and fine. I left the vehicle running while I was in the store. When I came back out it was not blowing cold air. I opened the hood and the compressor was not engaged. I tried to get it to come back on for a while and nothing happend. I parked it at home for a hour or two. I left again in it and the air was cold again. Drove it about 10 minutes and worked fine. My question is if it gets low on freon will it do that. I have only had a vehicle to quit blowing cold for good not off and on. If so there is a port on the dryer with a little end and the line by the radiator has a port, big end on it. Which one do you put freon in. The big in line or little on dryer? If anything else might cause this please help me out?
Re: A/C problem
Next time this happens, (compressor is off when it should be on) find a blunt object, broomstick, whatever and tap on front of compressor, see if armature plate pulls in, if it does, keep reading... your air gap is too wide and a shim needs to be removed.
Air gap (distance between armature drive plate and pulley face) should be near .020" yours is probably near .050" if you have higher mileage on your TB. The electromagnetic field can pull in the drive plate when coil is cool, but has trouble when coil warms. Once pulled in, it will stay in, but once released, it will not pull in when warm. Seen it a bunch of times. You'd be surprised as to how many compressors get replaced for this common issue. Shims are behind drive plate, bolt (or nut) on front of compressor needs to be removed and drive plate wiggled off, then be careful to remove the thickest shim (if more than one). Replace drive plate, tighten bolt and be good to go for another 100k miles.
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
Re: A/C problem
Multiple failures have been noted on these trucks related to a bad a/c pressure switch in the high side system.
Re: A/C problem
