Old 05-28-2003, 12:00 AM
Deejay27's Avatar
Deejay27 Deejay27 is offline
Having a slight problem with 1/12th scale F1 project...ran into a problem+need help
Ok...I am close to completing the kit. Yesterday, I attempted to paint the rims w/ Tamiya's semi-gloss black (spray can) and prior to spraying the black on I washed the rims in soapy water, rinsed well, dried well, primed with Tamiya primer, and let it dry overnight in the food dehydrator (nothing different on how I painted other parts of the kit). Everything was looking good prior to spraying the black on. As you can see from the pic below the rim didn't come out very well. Although I am only showing a pic of one of the rims...this occured with all 4 rims !!! The weird thing is the bubbles were only around the lip of the rim and no where else. I proceeded to sand down all 4 of the rims today (the lip only) and re-sprayed the black and guess what......it bubbled up again !!!!! What is causing this? The rims were cleaned well prior to spraying. What could be reacting with the paint to cause it to bubble up like that for the second time?
I will be posting more updated pics by the end of the week and if you would like to see the thread...click the link below.
Jimmy
Current Project
"Tamiya 1/24th scale Enzo"
Completed Projects
"1/12th scale Renault FW14B"
"1/24th scale McLaren MP4/7"
Old 05-28-2003, 12:04 AM
aw1234dude aw1234dude is offline
Send a message via ICQ to aw1234dude Send a message via AIM to aw1234dude Send a message via Yahoo to aw1234dude
Maybe you should try alot lighter mists like so paint barely gets on it and just do like a whole bunch of coats. I'm thinkin cause its such as small surface bubbles can form really easily.
Old 05-28-2003, 12:07 AM
Deejay27's Avatar
aw1234dude.....the paint looked smooth when it was done spraying. It started to bubble up during the drying process.
Jimmy
Current Project
Completed Projects
Old 05-28-2003, 12:10 AM
Murray Kish Murray Kish is offline
Getting Old...
Weird, only thing I can think of is to sand it down again and wipe it thoroughly with alcohol. It must be reacting with some sort of chemical on the surface???
Murray
Old 05-28-2003, 12:23 AM
christofurr's Avatar
christofurr christofurr is offline
How soon after painting did you put it in the food dehydrator? The only thing I can think of is that you should let the paint 'dry' at room temp. for an hour or so, and then put it in the dehydrator to 'harden' after that?
Old 05-28-2003, 05:48 AM
daggerlee's Avatar
Maybe your coats were too thick?
Dan
Old 05-28-2003, 12:05 PM
racer917's Avatar
racer917 racer917 is offline
Same thing has happened to me when spraying bike rims. It looks ok when wet but as it starts to dry bubbles show up. I'm sure it's too thick a coat of paint. Sand it down, two light mists of paint follow by a heavier coat. It should take care of that.
Old 05-28-2003, 12:12 PM
freakray freakray is offline
AF Modelrater
I have to agree with Dan on this one, if you're painting the rims with to heavy a coat of paint, as it dries it will trap gas in the paint and form bubbles.
Try spraying lighter coats of paint, you don't have to cover everything with one coat of paint.
Ray
AF User Guidelines
Old 05-28-2003, 08:08 PM
Deejay27's Avatar
Thanks for the replies. I'll give it a try with lighter coats. It's just hard to spray the inside of the rim without it building up on the lip.
Jimmy
Current Project
Completed Projects
Old 05-28-2003, 08:56 PM
935k3's Avatar
935k3 935k3 is offline
You might already do this, I always spin wheels fairly fast when I paint them, this always gives me a nice even coat without build up. I always keep them moving when I spray. The bubbles are most certainly from too much paint sprayed to close. I would strip them and start over or sand them and airbrush on a final coat.
Old 05-28-2003, 09:09 PM
Getting Old...
Spinning the wheels is a really good idea. I just added that to my little collection of 'reminders' for my next project. Thanks..
Murray
Old 05-28-2003, 10:33 PM
Deejay27's Avatar
Hmmm....spinning the wheels....I'll give it a try.
Jimmy
Current Project
Completed Projects
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
