Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-10-2011, 01:43 PM
n2racing n2racing is offline
89 2.8 stumbles when warm
I have an 89 Camaro that runs well cold but when it reaches 180 degrees it begins to flutter and miss under acceleration. If I let up it smoothes out a little. I get no codes and the scanner doesn't pick up any abnormalities that I can see. Any Ideas?
Thanks,
Darrin
For Only Real Drivers
Old 05-08-2011, 09:30 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: 89 2.8 stumbles when warm
Check fuel pressure. You can rent a gauge at autozone if you don't have one of your own.
If your fuel pump is on its way out, it will present lower pressure when warm.
Old 05-17-2011, 11:51 AM
Fuel Pressure was fine. Checked the timing. Factory setting is 10 degrees btdc. It was set at 2 degrees atdc. I adjusted it and in runs fine. The knucklehead who worked on this before had to have played with the timing. There is no reason to adjust factory settings. If you feel the need to adjust...replace the timing chain.
'92 K1500 350 TBI stumbles and recovers while braking / slowing down when warm 1993Suburban C/K 2 03-27-2010 06:55 PM
No start, has spark, has fuel, only when warm? anyone? ateball7 Achieva 0 02-14-2009 08:19 PM
94 k1500 stumbles when warm bones001 C/K 0 02-03-2007 03:53 PM
90 Accord engine stumbles when warm Steve316 Accord/TSX/Accord Hybrid 3 06-18-2004 10:24 PM
91 cavy 2.2 runs poopy when warm ebritt Cavalier 0 05-26-2004 09:21 PM
