Old 06-06-2004, 10:24 AM
Steve316 Steve316 is offline
Exclamation 90 Accord engine stumbles when warm
My daughter's 90 Accord LX starts and idles fine then after it warms up and the rpms lower it wants to stumble and die when you do anything but push very gently on the accel. pedal. it does fine except when you go to accelerate after a stop or if you have it in park and give it gas. I put a new fuel filter, plugs,wires, cap & rotor. Please, any hints?
Old 06-06-2004, 09:57 PM
x128phantom x128phantom is offline
Re: 90 Accord engine stumbles when warm
The problem may be the transmission. could be slippage and overworn clutch. To fix this you may need to buy a new transmission.
Old 06-18-2004, 08:42 PM
carbonaccord69 carbonaccord69 is offline
Try a diagnostic; I had a 1986 Accord that needed a new computer part that was telling the ecu that the car was still cold, so the fuel was too rich. My car would be flooded, and would not start for 5 minutes. Computer was about $200+diagnostic.
Old 06-18-2004, 10:24 PM
LeeH LeeH is offline
No check engine light on? Here's how to pull the codes from the computer. Read this info carefully and see what you come up with. The symptom you describe is the same that I was having when my ECT (engine coolant temperature) sensor was bad.
The sensor sends a signal to the computer which adjusts the mixture based on the temp. When this sensor fails it usually only sends a bad signal when hot... and it tells the computer the car is cold which results in flooding and the symptoms you describe. Here's the link:
http://www.cybertrails.com/~bestinth...acrdcodes.html
