Go Back   Automotive Forums Car Chat > Chevrolet > Chevelle
Old 04-09-2011, 06:15 PM
Echos Myron Echos Myron is offline
Rochester 2-barrel problem
Hi, I have a '67 El Camino which was originally equipped with a 190hp 283 and a Powerglide. I have located and installed a date-coded 283 which I was told came out of a farm truck (with a manual trans). I have discovered that the existing Rochester 2-barrel carb will not work with my power brake system. I had no idea that there was any difference. Does anyone know what model of 2-barrel I need to look for? Thank you in advance.
Old 04-10-2011, 09:01 AM
maxwedge maxwedge is offline
A990 racer
Re: Rochester 2-barrel problem
What is the issue, no vacuum port, how does the carb tie into the p/b system here?
Old 04-10-2011, 12:55 PM
Scrapper Scrapper is offline
AF Premium User
you can call jegs or summit or evan a dealer.
Old 04-10-2011, 06:31 PM
I don't know, but my mechanic said I need a "choke stove" if that means anything to anybody.
Old 04-10-2011, 07:12 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Possibly he means you have a thermal choke on the carb, and the intake manifold is not set up for one. This is unrelated to the bower brakes, though.
If this is the case, its easy enough to adapt a manual choke, though. It's not original but will get it working.
how about some pictures of the carb and intake?
The Following User Says Thank You to MagicRat For This Useful Post:
Tony Silva (06-23-2011)
Old 06-23-2011, 09:49 PM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
For power brakes, you will need to install a fitting directly into the intake to get the vacuum necessary to operate the brake booster. Connect some hose to the fitting...connect a one-way ball check valve to the end of that hose, then run more hose to the brake booster port. LOOK FOR A PIPE PLUG BEHIND THE CARB ON THE INTAKE MANIFOLD. REMOVE THE PLUG AND INSTALL THE FITTING.
OK, as for the carb choke issue. The choke stove IS the flat coil that operates the choke flap on the carb. In that year...the choke stove IS located under a plate...on the intake manifold...passengers side BELOW the carb...NOT ON THE CARB AS MagicRat posted.....I think there are two 3/8ths bolts holding the plate in place.
I think #1 There is no provisions in the manifold for power brakes due to the farm vehicle not require the extra power...and #2, no need for a choke on a farm vehicle due to the fact that the farmer removed the device BECAUSE......farm land is typically in warm humid territory which doesn't necessitate the gas wasting usefullness of a choke on a carb. Just my opinion. Could be wrong though.
1997 Chevy S10 2.2 Starts Then Dies Logan76 S-10 9 07-29-2010 03:44 PM
J-2 Rochester Tri-Power Ragtop_Renegade Oldsmobile Classics 2 02-13-2009 04:40 PM
Rochester 2 Barrel Carbs BelAirRoxy Chevrolet Classics 8 06-28-2008 01:39 PM
4 barrel throttle body or should i just keep my 2 barrel 92 V6 4.3 Pickup S-10 7 11-04-2004 10:47 PM
