Old 04-08-2011, 10:21 PM
spflick spflick is offline
97 taurus dtc codes
i just bought this 97 taurus gl with a 3.0l ohv i have dtc po402, p1131, p1132 im just wondering where i should start on these.... car misses sometimes at start up, bucks once in a while around 50....i have not found any vacuum leaks... help
thanks splick
Old 04-08-2011, 10:37 PM
Re: 97 taurus dtc codes
p0402- too much egr flow
p1131-lack of bank 1 02 transitions-lean
p1132-lack of bank 1 02 transitions-rich
Old 04-09-2011, 09:38 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Sounds like your Differential Pressure Feedback EGR (DPFE), aka EGR sensor, is faulty.
-Rod
Old 04-09-2011, 08:39 PM
thanks shorod, i was thinking that but wanted someone elses opinion as well before i replaced the part.... thanks all keep you updated.
Old 04-21-2011, 08:03 PM
ok i replaced the dpfe sensor and also the egr sileniod.... cleared codes.... got a p1131 again but none of the other codes.
any ideas?
Old 04-21-2011, 10:41 PM
shorod's Avatar
SHO No Mo
I'd suggest you check for vacuum leaks that would impact bank 1. Does the engine idle and run fine?
-Rod
Old 04-22-2011, 08:02 PM
it misses of and on and idles up and some sometimes then it runs ok. bank1 would be???? and does not seem to be a vaccum hose leaking on there.... where else to look?
Old 04-22-2011, 08:58 PM
tempfixit tempfixit is offline
Bank 1 is always the side that has number 1 clyinder on it, which on a ford is the left side when facing the front of engine. Closest to the firewall. Have you changed any plug wires?? Is it wet or raining when misses at start up? Have you tried the car cleaner trick to find a leaking vacuum line? Cleasn the MAF sensor also.
Old 04-24-2011, 09:15 AM
I have not had a chance to cleanse the sensors yet. throttle body is dirty so i am assumming the idle air control motor is dirty and the mass air flow sensor also. i planned on doing that also... o2 sensor look like originals.... car has 195,000 miles on it... i mainly was wondering what would just effect bank 1 vaccum?
thanks
Old 04-24-2011, 08:54 PM
shorod's Avatar
SHO No Mo
It wouldn't effect just bank 1. However, if you have a slow O2 sensor on Bank 1 and the sensor on Bank 2 is not quite as slow, that might explain the codes. Or you may have other issues besides a dirty air path.
-Rod
Old 04-26-2011, 08:57 PM
ok looked and and all of those sensors were dirty so i cleaned them anyways... still have the same check engine light so im going to put plugs wires and pcv and spark plugs and fuel filter in it come pay day and see if that might fix it... then well see where to go from there
Old 04-26-2011, 09:29 PM
Did you clear the codes after cleaning sensors then running it until or if the check engine light came back on??? If not do so and see what happens, otherwise it will take a number of drive cycles if everything is ok to turn off cel.
Old 04-28-2011, 09:29 PM
yea i had them cleared by autozone
04 taurus DTC 1633 portage07 Taurus | Taurus Wagon 1 10-18-2007 08:34 PM
2000 Taurus DTC code P0411 jmroller Taurus | Taurus Wagon 5 07-01-2005 10:23 AM
Maxima specific DTC Codes borgeeba Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 07-08-2004 10:07 PM
P0430 DTC Code - 2000 Maxima SE maximajim Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 06-30-2004 12:58 PM
