Go Back   Automotive Forums Car Chat > Cadillac > Cimarron
Old 04-08-2011, 11:34 AM
jagillick jagillick is offline
1987 Cimarron: Remove distributor cap
I have a 1987 Cimarron with a 2.8 liter V6 engine that has a leaking o-ring that goes around the distributor shaft cap that is placed where the distributor used to go since this is a distributor-less engine and I am having difficulty removing this cap due to buildup in crud and varnish and tried a bunch of automotive chemicals already. Earlier on I tried gently tapping on the top of this cap to try to jam it more into place to hopefully stop the leak which did not work but the cap did not have any dent marks from the tapping so I don't think I damaged it from tapping.
Any ideas on how to remove this cap?
Old 04-08-2011, 11:56 AM
maxwedge maxwedge is offline
A990 racer
Re: 1987 Cimarron: Remove distributor cap
vice grips.
high idle after spark plug/cable/distributor cap change gruvytune Dakota 0 07-13-2003 11:10 AM
1987 420 SEL Distributor Cap and Rotor JonathanM General Discussion 0 04-05-2003 10:16 PM
sparksplug wires and distributor cap minx General Discussion 1 10-27-2002 04:58 AM
How do I find position 1 on distributor cap? sares1 Engine and Transmission 1 05-10-2002 01:29 PM
Tags
cap
