Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '06+ Civic
Old 04-08-2011, 09:12 AM
JFol5 JFol5 is offline
Bad Thermostat most likely, now check engine...?
So three days ago, in the morning after the engine cooled all night, I was driving to work when my temp gauge went past the normal halfway point and continued to climb into the red. At that point, no heat was coming out, just cold air. I checked my coolant level and realized I was low, so I filled it with water for the time being. For the next 20 miles or so, the gauge was at a normal level. I got coolant, put it in, when I drove the next day, my temp gauge climbed back up to the red and only cool air came out.
I was told since it wasn't the coolant level, it's most likely the thermostat. I haven't had the time to replace this and on drive to work today, temp gauge up all the way, engine smoking, and finally a check engine light and little acceleration.
Will it still just be a simple thermostat replacement, or will there most likely be additional problems to fix?
Old 04-08-2011, 12:04 PM
inafogg inafogg is offline
Re: Bad Thermostat most likely, now check engine...?
it sounds like you ran low on coolant(need to find the leak)when you filled the
system you may need to bleed off any air thats trapped in system.
as far as thermo stuck ???it may be but i would'nt bank on it
the year & engine would help!!!since your in the honda forum i guess its a honda
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 04-08-2011, 01:25 PM
Karboodle's Avatar
Karboodle Karboodle is offline
It could be a more complicated issue. There could be a problem with the radiator or the water pump. It's best to get this checked out by a mechanic ASAP.
Old 04-08-2011, 08:29 PM
BullShifter's Avatar
Sounds like you may have over heated it one too many times. I wouldn't waste money one t/stat until some one verifies it does not have a blown head gasket.
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
1998 Malibu - check engine light jpar1983 Malibu 2 10-28-2009 07:49 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
