Go Back   Automotive Forums Car Chat > Geo > Nova | Prizm | Spectrum | Sprint
Old 04-07-2011, 06:51 PM
Scott46550 Scott46550 is offline
1994 Prizm runs hot at high speeds
My Prizm runs very hot at high speeds. No leaks, no coolant in oil, changed thermostat twice, bottom hose cool top hose hot, fans running fine, and blows out hot air from the heater. Blows coolant back into the overflow reservoir when hot. Could it be a clogged radiator or the system needs to be bled?
Old 04-07-2011, 08:16 PM
brcidd's Avatar
brcidd brcidd is offline
Re: 1994 Prizm runs hot at high speeds
You said top radiator hose is hot, now does radiator itself get hot, all the way top to bottom? side to side? if not, she's all clogged up- wherever it's warm, there is flow, where it is cool, no flow- pretty simple to check- the hard thing may be being able to feel the entire surface areas. I'd replace it if it's cool- boneyard or new is your choice.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Vibrations / sound at high speed Elias125 Engineering/ Technical 5 05-19-2010 05:05 PM
1994 Prizm possible transmission problem theginchico Nova | Prizm | Spectrum | Sprint 0 04-11-2010 12:52 PM
a/c blower fans only run on high speed drewz7046 Caravan | Voyager 4 02-21-2008 10:49 PM
76' Ford F100 6cyl runs bad @ high speed RAYDIOED M Bodies 3 12-06-2005 02:44 PM
Blower motor runs on high speed only spackey Cherokee 5 07-31-2004 01:29 PM
