Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 04-05-2011, 06:01 PM
Samples08 Samples08 is offline
Exclamation Need help plz
ok its been about a mouth now and i still have not figured out what is wrong with my fog lights on my 2002 pontiac bonneville can anyone help me this is driving me nuts i need those lights
This is what ive done,
checkd all the fuses
and replaced relays like crazy
changed the switch
and still no fog lights
Samples
Old 04-06-2011, 12:18 AM
FORDGUY09's Avatar
FORDGUY09 FORDGUY09 is offline
Send a message via AIM to FORDGUY09 Send a message via MSN to FORDGUY09 Send a message via Yahoo to FORDGUY09
Re: Need help plz
have you check the bulbs yet? the wiring at the fog lights? and there stock right?
1997 Honda Accord
2003 F250 6.0 ps cclb
2016 jeep patriot
Old 04-06-2011, 12:36 PM
savagecowboy_69 savagecowboy_69 is offline
Re: Need help plz
check the sockets u might have a broken contact
Old 04-06-2011, 02:29 PM
FORDGUY09's Avatar
Re: Need help plz
and what switch did u replace? headlight or fog light?
1997 Honda Accord
2016 jeep patriot
Old 04-15-2011, 01:31 PM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
Re: Need help plz
I would be happy to look into this as well. In order to do further research, I will need the VIN for the vehicle as well as the current mileage. Please feel free to contact me via private message if you would like. Thank you in advance.
Tricia, GM Customer Service.
Old 04-18-2011, 07:27 PM
Re: Need help plz
yes i have check the bulbs and i changed the fog light switch and yes they are factory fog lights!
Samples
Old 04-22-2011, 08:40 PM
eippermx's Avatar
eippermx eippermx is offline
Re: Need help plz
Press the fog light switch to the on position. IF it lights that tells you that the fog light relay is working, the switch is working providing voltage over to the HVAC/IPM & DIM. Using a volt meter, select one of the lights and remove the light bulb from the socket. Probe either your purple/white-stripe left fog light) or purple (right side fog light) wire for 12 volts. If you have 12 volts then you're getting power from the relay and power side is working. Looking on the top of tranny, located there is some grounds one of them is the splice pack. Its a black plastic square box. Unbolt it, check for corrosion, take apart the pack itself and clean it. Put it all back together. IF that doesn't work, then the simplest thing to do is tie a ground wire to each socket. If you have a problem with power then you need to pull the fog light relay and probe for 12 volts from the fog/drl fuse and determine if you have a broken wire issue between those points or a bad fuse. If none of that works, then the Dash Integration Module (DIM) may have an issue because it controls the relay OR there is an issue with the serial bus wire that provides signaling to the DIM to tell it to provide the ground to the relay or there is an issue with the HVAC/IPM ((intstrument panel integration IPM)) module, or the fog light switch itself. Go to autozone com, plug in 2002 bonnie, look up the fog light diagram for more information to follow along this post.
mark
Love my Pontiacs!
'04 GP GT1
'02 Bonneville
'98 GTP - 2 dr
'98 GTP - 4 dr
'99 GP "Flaming Tomato" GT
NEED help plz plz plz!!!! jason11762 Exterior | bodykits | Lighting 0 09-21-2003 08:53 AM
Need Help PLZ Touge180 '88 - '91 Civic | CRX | Wagon | Shuttlee 3 05-03-2003 10:53 AM
Need Help Plz! rally_lover Lancer 2 03-30-2003 10:53 PM
'92 s-10 2.8l belt... need help plz El_Hefe General Discussion 1 12-17-2002 09:27 PM
