Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 04-04-2011, 09:49 PM
cruiser69 cruiser69 is offline
Brake Issues
I have an 06 Impala LTZ with about 49k on it. I put new rotors and pads on the front a week ago and had not problms. Now all of a sudden the brakes sound like they are grinding on the drivers side. I have rechecked everything and do not see anything wrong. Does anybody have an idea what could be the issue.
Old 04-04-2011, 10:57 PM
inafogg inafogg is offline
Re: Brake Issues
when do you hear the grinding noise??
all the time,just when brakes are applied??
when the brakes were replaced were the calipers n pins lubed??
were the rotors cleaned before installing them??
was there any anti squeal/disc brake quite applied to pads??
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 04-05-2011, 06:59 AM
Re: Brake Issues
I only hear the grinding when the brakes are applied when coming to a stop. The caliper pins were lubed, rotors were cleaned and disc quiet was applied to pads. I was wondering if they are just still trying to break in.
Old 04-05-2011, 10:13 AM
Scrapper Scrapper is offline
AF Premium User
Re: Brake Issues
sure it's not a bearing or the rear brakes your hearing.
Old 04-05-2011, 10:53 AM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: Brake Issues
What brand of brake pad did you use?
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 04-06-2011, 11:45 AM
Re: Brake Issues
I does not sound like a bearing or the rear brakes. Sounds like it is coming from the drivers tire. I used Raybestos pads and rotors for replacement. I used them before and did not have any issues.
Old 04-06-2011, 06:21 PM
AF Premium User
Re: Brake Issues
yah sounds plays tricks on you sometimes.
good luck........
Old 04-06-2011, 10:30 PM
SierraK1500's Avatar
SierraK1500 SierraK1500 is offline
Re: Brake Issues
Pull the wheel on the driver's side or what ever side is making the noise. Pull the caliper and inspect the brake pads. If they are scored or show metal they are bad. Make the auto place replace your rotor too. Also check the bearings and make sure they were pressed in the hub correctly. If not take the car to the dealer and have them look at it. You might have bad pads right out of the box. Did this happen right away or increase in sound over time?
02 with very loose brake cable capncar Ranger | Courier 5 04-04-2011 09:27 PM
Brake issues GodsGirl73 Caravan | Voyager 4 05-05-2010 04:45 PM
2000 blazer / jimmy brake bleeding issue rmwilson Problem Diagnosis 11 12-16-2009 10:14 PM
03 Malibu Brake Issue frame1520 Malibu 1 03-01-2009 09:25 AM
help, speratic brake issues and throttle-off-idle issues. 94tegRS Camry/Camry Hybrid/Vista 3 11-08-2006 02:56 AM
