Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 04-04-2011, 09:56 AM
capncar capncar is offline
Arrow 02 with very loose brake cable
The parking brake cable on my 02 Ranger has, over time, gotten very slack, so much that the brake just barely grabs when i push the peddle to the floor. Ive checked the star gear adjustment and brake shoe thickness, and both are good.
Could be that this cable has stretched this much (approx. 5") and needs replacement? I see no means for adjustment.
Any ideas?
One day at time.
One car at time.
Old 04-04-2011, 02:23 PM
inafogg inafogg is offline
Re: 02 with very loose brake cable
the cable should be adjustable,look at the midway point on drivers side
running along the frame.making sure the brakes are adjusted properly first.
then adjust the cable for e-brake.
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 04-04-2011, 03:23 PM
Unhappy Re: 02 with very loose brake cable
Yea. On other models/cars you often see 12" of threaded rod that you can use to take up the slack, but no such rod exists along the whole cable.
One day at time.
One car at time.
Old 04-04-2011, 03:41 PM
if its non-adjustable then you need a new cable
just to be sure you have rear drum brakes???
Live For Today
Yesterday is gone,
Old 04-04-2011, 08:13 PM
toddler62 toddler62 is offline
I think your adjustment is in the car on the parking brake pedal assembly at the top where it pivots.
Old 04-04-2011, 09:27 PM
good point do you have thr ratchet type set up??
if so you need to pump the e-brake pedal for adjustment,
not sure they used them on the Ranger though...
Live For Today
Yesterday is gone,
brake problem, VERY hard brake pedal but VERY little braking power 95GMCJimmySLE Problem Diagnosis 23 10-24-2009 02:41 PM
1998 Ford contour Parking Brake Very loose how to Adjust tomtina200 Contour 0 01-08-2008 03:07 PM
Loose window cable ? Diagram ? fenderbender339 Accord/TSX/Accord Hybrid 1 09-05-2005 11:55 PM
Clutch pedal feeling VERY loose 1Bad89GT Escort 1 05-13-2005 09:51 PM
Steering very loose 98 f-150 JasonTK F Series 1 04-13-2005 08:38 PM
Tags
brake , cable , parking
