Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 04-04-2011, 08:59 PM
Youngster513 Youngster513 is offline
2000 Chevy Impala Electrical problem
I have clicking noises coming from both of my fuse boxes and I thought it was the relays so I replaced all of them and the problem still occuring. And while its clicking all my interior lights and my head/tail lights are flickering everytime my fuse box clicks. I was wondering if anybody has any problems similar to mines and if I should get newfuse boxes.
Thanks.
Old 04-05-2011, 07:54 AM
brcidd's Avatar
brcidd brcidd is offline
Re: 2000 Chevy Impala Electrical problem
You need to isolate which relay(s) is "clicking"- put your fingers on each one to determine (feel) which one it is. Once you find it, you will know what circuit it is on and how to trace it from there.
The lights dimming may only be a result of extra power draw while relay is clicking- and not the cause of the problem.
Report back once you decide which relay is clicking.
Also, wiggle your ignition switch, does this affect clicking noise?
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
The Following User Says Thank You to brcidd For This Useful Post:
Youngster513 (04-06-2011)
Old 04-06-2011, 10:55 AM
I found which relay was clicking and it was my Park LP Relay so I replaced that and the clicking sound still continues from same relay.
Old 04-06-2011, 12:30 PM
brcidd's Avatar
The Park Lp relay is controlled by the Body Control Module (BCM) See if the ground leg (the one being controlled by the BCM) is going back and forth to ground. Use your DVM digital volt meter to see if continuity to ground is intermittent- probe ground socket of relay coil with voltmeter set on continuity. If so, then BCM is in question- most likely bad.
'99 GMC Yukon
2000 Chevy Impala Headlights Don't Work LadyQueen61 Impala | Impala SS 34 01-14-2017 10:55 AM
2000 Chevy Impala Service Vehicle Soon Light BryHPD Impala | Impala SS 13 12-16-2012 01:11 AM
Electrical Problems...... GaryCifers Corsica 6 01-13-2010 04:08 AM
2000 Chevy Impala coolant system legalinda Impala | Impala SS 11 02-15-2008 05:15 PM
2000 Chevy Impala Taxi xpeed Diecast Car Modeling 15 07-26-2006 01:15 PM
