Old 04-04-2011, 02:00 PM
cruiser69 cruiser69 is offline
02 Sensor
I have a 02 GT with 89k on it. Twice in the last two days I have gotten PO141 check engine code for the O2 sensor. Is this the sensor after the manifold or after the CAT. I am assuming I just need to replace it since it is throwing a check engine light. Thanks for the help.
Old 04-04-2011, 03:48 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 02 Sensor
P0141 indicates a problem with the heater circuit for the post cat oxygen sensor. Most of the time, this indicates the sensor's heating element is bad, but it could also indicate a wiring issue.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-04-2011, 03:53 PM
Re: 02 Sensor
I will check the wiring on it. Is there any certain brand you should use for replacing the sensor?
Old 04-04-2011, 04:07 PM
richtazz's Avatar
Re: 02 Sensor
I would stick with AC-Delco, Delphi or Standard. Don't even get me started on Bosch (aka JUNK!!!!!).
o2 sensor danielgast46 F Series 0 03-15-2009 10:39 PM
Replacing Evap. canister Control Valve, Boost Sensor, and Knock Sensor? raja Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 16 06-04-2007 04:25 AM
Knock sensor and O2 sensor jmmax Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 02-24-2004 12:51 PM
