Old 04-04-2011, 12:39 AM
outkast83 outkast83 is offline
Angry serious help
96 blazer w series 4.3 vortec
Was running ok and wouldn't start one day. Fuel pump seemed ok as wasn't losing pressure and could hear engage. New plugs, wires, cap, ignition rotor, fuel filter, air filter, fuel regulator, 2 of the 3 o2 sensors and a new tps. It starts and when I pus in on the gas it dies. There is a misfire on cylinder 1 and its the only code. Have changed spark plug 4 times. It runs for abot 1 mins and when you press on gas no matter how hard it does not go any faster than 10mph and usually dies before it moves..only when pressing on gas...I'm in about1000 on repairs due to towing and all the other bs involved. I need some serious help as I've spent all my savings and have jeopardized our family moving into a newhouse because we,ve spent all our money and we don't make much anyway. Please if anyone can help. I've put injectgor xleaner in and helped before it was running bad but ththen one day on the highway it wouldn't accelerate. Conmpressions seems good on the cylinder and a few mechanic savy friends have looked but we are stumped and I'm flat broke.
Old 04-04-2011, 02:26 AM
viggy58 viggy58 is offline
Re: serious help
sounds like a fuel pump maybe...
get a gauge and post your exact pressures.
Key ON, engine OFF, fuel pump running: pressure must be 60psi to 66psi and must remain above 55psi for 10 minutes after the pump shuts off.
also, make sure you have a nice blue spark at the plugs.
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 04-04-2011, 03:21 PM
inafogg inafogg is offline
Re: serious help
pull your 02 sensors & see if this improves performence
if it does you may have a clogged convertor
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 04-04-2011, 06:44 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Re: serious help
It sounds like a plugged cat to me too.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Old 04-12-2011, 03:02 AM
Re: serious help
Well its nogt the cat converter...cut it off..still rus the same..getting good compression as well
Old 04-13-2011, 06:04 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: serious help
Why did you cut the cat off?
You need to do some proper testing first.
Check fuel pressure for up to par.
Post back fuel pressure readings key on engine cranking and engine running and the engine running on the road pressure test?
Did you use AC Deco replacement parts and Delphi fuel pump?
Remember Gm engines hate after market off brand stuff.
I have even saw them refuse to start or run with white box stuff!!!!!!!!
MT
Old 04-13-2011, 08:06 AM
brcidd's Avatar
brcidd brcidd is offline
Re: serious help
Well, that cat is worth $60 at your local scrap metal yard...since you don't want it, go sell it and buy a $15 fuel pressure tester....and save the rest for more repairs.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 04-14-2011, 02:21 AM
Re: serious help
without the cat, the o2 sensors arent going to be able to adjust fuel trim correctly...
2001 Chevy Blazer
4.3L 5 speed manual
145k miles
146k miles
Need serious help with my bimmer guys... a5ian5murf 3 Series 5 09-26-2006 03:39 PM
PLZ HELP!!!Speedometer! Need serious Help! raziullah007 Prelude 2 02-27-2006 07:49 AM
HELP! Need serious help with auto tranny troubles firedawgy Excel 0 10-31-2005 07:15 PM
I need some serious help/advice Oz Asia/Pacific 13 03-20-2002 08:36 AM
