Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 04-03-2011, 05:55 PM
josephc04 josephc04 is offline
Issues starting 1999 zx2
I have an issue with starting my 1999 zx2. When I turn the key, I hear one click, which I assume is the starter engaging, but no crank. If I continue to hold down the key for a few seconds the engine then cranks and starts up. It doesn't always do it, just most of the time. I don't know what could cause a delayed start like that. I've put two new batteries in this past year. Alternator tested good. Any ideas? Could the starter be going bad?
Old 08-30-2011, 02:14 AM
mchlcordell mchlcordell is offline
Re: Issues starting 1999 zx2
I have a 2002 zx2 with the same problem a while back, but my problem was that the ecu (emission control ) module was going out, its located under the cup holder which was a good spot for spillage to happen which got into the harness and ever since that the car would not start. and when i got it to start, it only ran for a few seconds. but from what your saying it sounds like it could be anything. i have had problems in the past with the alternator being crap and the car still running on the battery till it could not run anymore. fuel filter problems etc.
2002 Alero, no panel lights, no start after sitting overnight. mndadof2 Alero 1 08-27-2010 04:22 PM
1999 ZX2 No Start Problem chcs28 ZX2 4 11-08-2008 08:07 AM
1999 Zx2 coolant temp sensor NHTennis ZX2 8 05-14-2007 10:57 AM
1999 ZX2 Engine Replacement bmenzing ZX2 1 05-27-2006 12:18 PM
1999 ZX2 Rim Size zx25spd ZX2 2 06-26-2005 12:40 PM
